2wd vs. 4wd 4l80e
Old Aug 27, 2004 | 11:24 AM
blownZ71's Avatar
Default 2wd vs. 4wd 4l80e
I have found a good deal on a 4l80e setup for 2wd. What would it take to convert it to a 4wd application? Would it be worth it?
Old Aug 27, 2004 | 01:45 PM
James B.'s Avatar
It just needs a new Output Shaft and Housing. That's the easy part. A complete disassembly is required to get to the tailshaft.
Housing: 8677464
Output Shaft: 24204289
I'm fairly sure the housing comes as an assembly with the outer and inner seal and the bushing pre-installed. Six bolts will be required to hold it on. Two bolts hold the rear mount. The rear mount is the same as a 2WD 4L60-E but not a 4x4.
EDIT - looks like I read it backwards. The above info is for making 2WD out of a 4x4.
Old Aug 28, 2004 | 04:20 PM
blownZ71's Avatar
ttt bump ???????
Superman09
Sep 25, 2015 05:55 AM
God Made Chevy
Sep 4, 2015 12:29 AM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
