233/239 113 in a 5.3: Sound clip
#32
I'll definetly be coming to you if I need help tuning a big cam.
Does sound mean... too bad you said power kicks in so late (4500).
100mph @ the 2-3 shift isn't too bad either. It's time for you to catch some street races.
I was worried about throwing in a cam with 0* of overlap @ .05'' much less, 10*
I was just thinking... "how can you get that sound but, not have to shift at 7000rpm"
Seeing as you were able to tune that out, you could set up a cam for example like the following: 220/222 106lsa, 8* of overlap and has an IVC point of 37* which should keep peak hp around 5800-6000.
It would rip.
It would rip.
#38
Thanks for the props!
To be honest, I've not had it uncapped except at the track and it was running like ****. It flat out would not idle uncapped. The idle does suffer with the cutouts open.
lukn4trbl355
Oct 21, 2015 11:19 PM
