220r with milled 799 heads
Has anyone ran that combo, it's an 06 silverado dished pistons. The cam has 110lsa, I seen a few ppl running the 220 but I haven't found any with .600 lift
Avery@texas-speed.com
The combo should run pretty well! I would mill the heads about 30 thou to get the compression back. The cam will have around 0 degrees of overlap so it should have a nice sound to it. Run it with a 3000-3200 stall and you should like it.
I ran the 220r with LM7 heads and intake and it was the most fun my truck has ever been! One of my fav cams for the 5.3s with a 3000+ converter
That's what i need next is a higher stall, feels like a slug till 3k rpm, I have a 2009 intake manifold with injectors and fuel rail on the way. Just need to get the heads milled and swap them over. Thanks fellas
