20's and mpg?
Old Oct 30, 2007 | 07:48 PM
  #31
TouchOfEvil04's Avatar
If that dumbass logic were true then by your "theory" if we can even call it that...then when i swapped over to 20"rims but stayed with the same width/height of the trie then my mpg should have stayed the exact same.
Sorry to say it did not. I dropped off about a mile per gallon and i lost 3/10's in the quarter mile.
Only change was rim size and tire mount size.
The overal weight of the tires was exact as well as the width and height of them.
The rims however weighed about 15lbs heavier each.
So go do some math in your make believe world and explain this to me once more cause i'm not getting it.
Old Oct 30, 2007 | 07:49 PM
  #32
Thank's for typing all that so I didnt have too... haha. Case in point, my 20's with tires are the same diameter as my factory 17" wheel and tires setup. However my 20's are a decent amount heavier, Chrome 20's vs. Alum. 17's. With the 20's on I get about 1.5mpg less give or take, I also notice a slight diff. in accel and decel but only when WO or under hard braking. So why do I run the 20's then you may ask... I think they look purdy.
I just said the same **** same time haha. Oh and mine look purdy to...at least to me so i gots to roll em.
Old Oct 30, 2007 | 08:36 PM
  #33
silveradol33's Avatar
I took my 22s of my truck and went back to stock rims and stock tires, my 22s had bigger tires also, I dont think I saw but maybe, maybe 1 mpg better all around, if that! I did feel a power difference tho. Im sure they factor in but not 4 or 5 mpg like some people claim!
Old Oct 30, 2007 | 09:53 PM
  #34
Freakenhye's Avatar
Originally Posted by RandomHero
Dude you are throwing out all this technical jargon and it means absolutely NOTHING.
"My friend got 21 mpg and I get 23 with 20's so it must be true"
Do you realize how stupid you sound.
first of all 20" rims(on the average unless using billet) are much heavier than a stock 16/17" rims.
Secondly, like said, the rotating mass is pushed further out.
Third, you have no idea what you're talking about.
Physics doesn't lie. Hell if you want to throw out the "Objects in motion will remain in motion unless acted on by an opposing force" bull **** then I'll remind you that we all drive a 5000 lbs brick that is about as aerodynamic as Rosie O'donell
Here is what is going to play a factor in your gas mileage:
RPMS- Obviously if you spend time at WOT throttle you'll get terrible gas mileage, however, go too low and you'll be constantly downshifting on hills.
Speed-While related to rpms there is also another factor to take into account....the law of diminishing returns. you may get 15 mpg going 50 mpg and 20 mpg going 70 mph but you won't get 25 mpg going 90 due to aerodynamics and the higher rpms the engine will be turning.
What you're driving-we're driving a truck, it isn't a ford gt or a ferrari, there are very little aerodynamic features that silverado's have.
Rotating mass of the wheels-I have experience on this both from personal experience and from a scientific approach. Having the rotating mass be pushed out further allows outside forces to play a factor in how easy the wheels turn. The further out the rotating mass is taken the more momentum,leverage,etc play a factor.
Anybody can throw out useless terms and then follow it up with "well my buddy got 25 mpg once with his 22's." When you say something like that you lose all your creditability.
First of all . Unless you realize that its miles per gallon, and not average miles per gallon, if we are talking about average miles per gallon whitch includes uphill climes, with downshifting involved then yes then you are right. Becuase your whole idea of downshifting on hills cannot be applied to this conversation, being that everyone knows smaller rims and tires are good for acceleration, this is why you dont see 20" rims with slicks on it, but Im talking about crusing at 65mph, and a truck with 20" rims will get more mpg then a truck with 17's, and yes we both tested each others trucks. That has nothing to do with the fact the he saw less, but since you wont be happy untill same driver and same techniques are used then i will do the fallowing.
I just called up my brother and requested 2 silverados to put an end to this conversation we are having, I have gotten hold of a 2 x 2007 silverados 5.3L Extra Cabs both with AFM, both with 3.73's, one with 20's and the otherone with 17's, i will do my testing hopefully this weekend.
Testing will go as fallows.
2 mile run down a freeway at 65 mph on cruise control,
i will get the truck up to speed hit cruise control and drive for 2 miles. then record the findings.
If im wrong i will apologize.
Old Oct 30, 2007 | 10:14 PM
  #35
1ORANGEWS6's Avatar
Man I think you are really missing the point. We are not talking about acceleration here for smaller wheels and tires. We are talking about heavier rotating mass. My STOCK wheel/tire combo is the SAME diameter as the 20" wheel/tire combo. The only difference is the 20's weigh more. I'm no scientist but it takes more power to move a heavier rotating mass therefore using more fuel. I lighter rotating mass will take less power to move therefore better MPG.
Also everyone uses AVG MPG to calculate their fuel mileage to take into account of their various types of driving on a tank of gas.
Old Oct 30, 2007 | 10:24 PM
  #36
Freakenhye's Avatar
Ok no one was talking about accelration. im gonna do a cruise at 65 for 2 miles, have you tried to push a car and once you got it to move you can keep it moving with little effort.
its the acceleration of the weight that eats up the gas. But at speed which lets say is 65mph on long trips a 20 inch rim will get more mpg then a 17 inch rim.
Once again if im wrong then i will admit it.
Old Oct 30, 2007 | 10:49 PM
  #37
SnakeOiler's Avatar
... But at speed which lets say is 65mph on long trips a 20 inch rim will get more mpg then a 17 inch rim.
If the tire diameter is greater with the 20's than the tire diameter on the 17's, then I would agree with your statement.
Do not confuse rim diameter and tire diameter. You can run different rim sizes and still maintain the same tire diameter.
Now, as for my truck, I have never seen any change in mpg with any of the mods I have done, and I am religious about keeping track of it.
Though, I have seen changes in my mileage based on the way I drive it.
Old Oct 30, 2007 | 10:59 PM
  #38
Freakenhye's Avatar
Yes tire diameter is what i mean. Totally agree with your statement.
Old Oct 30, 2007 | 11:00 PM
  #39
1ORANGEWS6's Avatar
You were the one who brought up acceleration man. Also you keep forgetting to see here is that the 20" wheel combo and the stock combo are THE SAME DIAMETER so your theory is thrown out the window. I got better MPG with my stockers than the 20's that were the same diameter. You are some what correct on it takes less effort to keep an object moving but if an object weighs more it will take more effort to keep it moving unless you're going down hill.
Old Oct 30, 2007 | 11:29 PM
  #40
I just said the same thing earlier. I went from stockers to 20's but kept the same overal size tire and still lost about a mile per gallon.
