206/212 lope? Heavy or not?
Old Nov 13, 2003 | 08:59 PM
99Silver6.0's Avatar
Default 206/212 lope? Heavy or not?
How bad would the lope be on the Comp 206/212 on a 112LSA be? I downloaded some clips of the 212/218 114LSA and it didnt sound bad at all. When the engine was warm, you could tell it was there. Anybody hear the 206/212 in a 5.3?
Old Nov 13, 2003 | 10:18 PM
StupidFast's Avatar
I haven't heard the 208/212 but, I assume that it will sound stock. I think someone on this board has one.
Old Nov 13, 2003 | 10:24 PM
Stupidfast,
How did you like your 212/218 before you got the stall?? Was it a dog down low or did it somewhat compare to stock? Id kinda like to get the 212/218 and in time I will do a new converter. Just wondered how the truck acted before the stall. Have you dynoed yet?
Old Nov 13, 2003 | 10:32 PM
StupidFast's Avatar
The cam with stock tuning made 330rwhp with a 5.3 and ported heads, 350 with a stock 6.0 with stock tuning, 476 with 9lbs of boost, and 499 with 11lbs of boost.
I couldn't tell much low-end loss. However, I did get misfire codes and MAP sensor codes. I would get the stall first.
Old Nov 13, 2003 | 10:38 PM
What stall should I even get to accomodate that 212/218? This is my daily driver, dont wanna get too crazy.
Old Nov 13, 2003 | 10:48 PM
StupidFast's Avatar
I would say a Yank 3000 or a little larger. There is nothing wrong with the smaller cam and you could still get the 3000.
Old Nov 13, 2003 | 10:51 PM
How bad will it act for a while without a converter. Being is, I already have the cam. I got it from a guy here in town new in the box. I cant wait any longer and want to put the cam in!
Old Nov 13, 2003 | 10:55 PM
StupidFast's Avatar
Not bad at all. However, I think you will like the converter better.
Old Nov 13, 2003 | 10:56 PM
I do a bit of towing. Will that 3000 be a problem or should I look at a 2600?
Old Nov 13, 2003 | 11:03 PM
StupidFast's Avatar
Look at Yank's website, I am pretty sure you can do towing with the 3000. If you don't tow anything heavy I would stick with the 3000, but look ask the experts first. I would for sure go with the 208/212 cam for towing.
