2014 intermediate pipe.
Old Nov 5, 2017 | 01:23 PM
sbmalibu's Avatar
Default 2014 intermediate pipe.
Anybody find an intermediate pipe cheaper than the dynomax 55608? I want to build a custom exhaust for my truck so i really just need the flange to build off of so i dont have to cut my stock exhaust. Hate to spend 90 for a pipe im gonna cut down to just the flange if i can get the flange cheaper. I have all the pipe and muffler already. so jus need this piece.
Old Nov 6, 2017 | 11:11 AM
MattofEarle's Avatar
I went with this
https://www.summitracing.com/parts/sum-672330-ss
Then welded it on tubing I had already sitting in the shop into the muffler then found a used tailpipe and made it work on my 2015 RCSB Silverado 5.3L.
Old Nov 6, 2017 | 07:33 PM
sbmalibu's Avatar
And thats the same size?So i can use it to mate to my stock converter outlet? I dont want to cut anything because if i get rid of the truck i wanna be able to return it to stock exhaust.
Old Nov 7, 2017 | 10:03 AM
Mark Johnson's Avatar
Originally Posted by MattofEarle
I went with this
Thanks for the heads up, Matt. I'm peice mealing pipe and muffler and resonator from a 2013 Denali and so far I've had to run a reducer from the 2.5 to the 3" pipe- this should complete the job..........
Old Nov 8, 2017 | 07:54 PM
Good Luck 2001 Sierra.
I just used the male end of the kit welded to some 3" tubing and it bolted right up to the factory flange after the third cat no leaks. It also mates up fine to the Kooks y-pipe I have on now.
Old Nov 15, 2017 | 07:05 AM
Ryan Mills's Avatar
If you're still looking, I have an extra sitting around.... I cut the factory one right before the flex pipe and added a electric cutout at one point, but after my third cutout, I went back to factory. So, if you want that fitting, I can ship it to you.
Old Nov 15, 2017 | 11:37 AM
Don't know who that was directed to, but I'm all good, thanks Ryan.............
