2006 4.8 to LQ4
Old Sep 22, 2016 | 05:36 AM
cnqrthedirt's Avatar
Default 2006 4.8 to LQ4
I've done a ton of research and I know that it's possible and in most cases a direct bolt up swap but I haven't read anything about doing it in a 2006 but a lot of older years 99,01.
Is it the same procedure for a 2006?
I have a 2006 Chevy Silverado 1500 4.8 2WD auto trans.
Just want to make sure everything will be G2G so that I can look for an engine. I will most likely replace my trans too, maybe find a place to beef my original trans up if there are any good places near me.
Hope to hear back from some guys who know what they're doing.
Thanks
Old Sep 22, 2016 | 10:01 AM
FFDP's Avatar
The long block will swap over just fine.
Bolt your intake, throttle body, fuel rail, injectors etc etc and all that minor stuff and you have a 6.0 ready to go.
Then you need to tune it. All that can be done with the 4.8 computer, it's easy enough to copy over needed data and then tweak the tune from there.
Old Sep 22, 2016 | 01:21 PM
Fast355's Avatar
Thanks
Just get you a 6.0L /4L80E and don't worry about the junk 60E.
Old Sep 23, 2016 | 05:26 AM
Does the LQ4 have to be the same year as my truck? Also any other suggestions?
Old Sep 23, 2016 | 06:58 AM
Merctech2's Avatar
Look for a 05-06 lq4 and try to get the 4l80 with it. Change knock and the rear oil sensor and new gaskets especially rear main while the 6.0 is on stand. I went with solid motor mounts too while doing swap. Pretty straight forward. I went from 03 4.8 to 05 6.0 and everything went smoothly, doing the 4l80 was a little more time consuming but with all the info on pt was not hard at all.
Old Sep 23, 2016 | 08:42 AM
Alright will do thanks for the feedback, when I start the swap and this build I will create a thread so y'all can follow.
A few more questions before I go looking for an engine and trans.. I'm looking to turn my truck into a pre-runner. If you could go LS would you go LS or would you stick with LQ4? Would an LS swap still be as simple and if so what LS engine would you recommend and what year? Also trans?
Or could I rebuild a LQ4 for more horses before dropping it in?? Just weighing my options.
Thanks again
Old Sep 23, 2016 | 09:20 AM
Wolftrk99's Avatar
The lq4 is part of the ls family, most of the ls designation(ls1,ls6, ls2, ls3, etc) are aluminum block versions, the lq4/9 are cast block 6.0 gen iii and most of the lm series are the 4.8/5.3 blocks.... Either will bolt in, just easiest to find a gen 3 going into a gen 3 truck!!
speedy.5013
Aug 15, 2016 05:48 PM
Schiavonske1013
Aug 15, 2016 11:09 AM
midnightbluS10
Aug 5, 2016 08:03 AM
Kike817
Jul 21, 2016 10:36 AM
Schiavonske1013
Jul 7, 2016 09:45 PM
