2005 e-fan guys, which fan is which???
Not that I know for sure, but every left and right part that I've replaced has been L=driver's side and R=passenger's side...so I would *assume* that the fans are the same way.
Ok. Got them in and all wired up. Low speed doesnt seem like it ever wants to turn off. Even with the a/c turned off. I havent heard high speed..... Other than when I forced it to high with EFILive... Any pointers on a/c settings to use/try??
Here are the settings I used.
The AC settings are in PSI, if you use ones similar to mine the make sure you set up your inputs to PSI, I made that mistake when changing mine and did not work right.
Make sure you change
G1203 - Series Parallel
G0101 - Fan #2 control
Here are the stock 05 settings, too high for my tastes....
Originally Posted by BlackGMC
I did too, can you post up your settings?
Log your AC pressures and see what they are, then adjust your settings to your liking. I lowered mine so the both fans basically kick on when the AC is turned on, so the AC was cold..
