2004 Tahoe, 5.3l 243 head swap
Ok so I would need to have these heads decked .030, and just get a regular gasket set for the vortec 5.3. bolts etc..
im considering doing the lifters given the milage
Custm2500's Rude Friend
12498544 this is supposed to be the part number for 2 gaskets. Just under $40 for the pair.
Everything else would be standard. The push rods might need to be shorter but you would have to measure the preload with everything torqued up.
Ok great. Well that's good information. I'm starting to wonder if it's worth all the trouble. I was definitely hoping for a drop and go but looks like it's more complex than that
The head test is interesting but the drop in compression by them not milling the heads all to the same chamber size makes it sort of irrelevant. Get the compression equal across all the test heads and run it again.... might be surprising again. And honestly bump the compression ratio too to see what happens. It's not like GM slapped 243's on dished piston 5.3's and ran around with a big cam that pulls to close to 7000 rpm and 9:1 or less.... combo mismatch alert. Make the engine even GM's nominal 9.9:1 or just 10:1 even and go from there.
