2004 LQ4 In a '79 El Camino, Help with Fuel
Old Jul 5, 2007 | 10:27 PM
nonnieselman's Avatar
Default 2004 LQ4 In a '79 El Camino, Help with Fuel
We are gettin a 2004 LQ4/4L80E and goin to put it in the EL Camino.
We are goin to need some help with Wiring and Fuel.
Would we be better off running a Fuel Cell or what?
Could we run a fuel pump, Walbro 255? what about a Regulator?
Oh and the FBW TB, goin to get rid of that and go with a Cable TB. What will that consist of?
We are goin to be keeping it all stock for now.. just need to get it in and running, then got to get a Driveshaft made.
Any help would be appreciated guys!!!!
Thanks!
Old Jul 6, 2007 | 09:38 AM
Anybody??
TTT
Old Jul 6, 2007 | 09:58 AM
ranwalk's Avatar
Does it have the intake,fuel rails and all on it still? Is it a returnless or return style? I have a spare crossover tube and rails and pressure regulator for a return system. I would run that, then run an external Walbro pump.
Old Jul 6, 2007 | 10:59 AM
76LQ9TA's Avatar
I put an 02 LQ9 and 4L80e trans in my 78 trans am. For the fuel system I used a tanksinc intake setup with the walbro 255 pump. I bought a new stock tank for my car and cut a 4.5" hole in the top of the tank. I used -6 parker push to connect hose for the fuel lines and a aeromotive fuel filter attached to the subframe connector on the driver side. I also used a 10033125 gm breather valve. I hooked this up to the vent line and attached it above the rear axle. I had all of the evap equipment unhooked and tuned out of the computer. The tanksinc.com setup was $225, the filter was $80 and the hose was $1/ft. This was with the truck intake manifold. It just barely fit under my shaker hood.
Old Jul 6, 2007 | 05:40 PM
Quik's Avatar
5 year bitches!
you could use an external pump and use the corvette regulator/filter. thats what we used on th pinks car and what a buddy used on his 78 malibu with a 6.0 swap
Old Jul 7, 2007 | 02:16 AM
Yes,, it is complete.... it is Returnless,
Ok... that sounds good.... and i was thinking a inline Walbro would work... just wondering about the Regulator... Thanks Randy...
Old Jul 7, 2007 | 02:17 AM
Dang bro... we might be talking alot more later on....
Just got the Engine/Trans today... so its goin to be awhile before any progress is made...
Its goin to be sweet once we get it rolling!!!!
Oh and Turbocharged next summer....
Old Jul 7, 2007 | 02:18 AM
Thanks Quik,
I was in a hurry, so i didnt get to take a good look at it...
Im goin to sit down and look it over tom and try to get a mental starting point.
Old Jul 7, 2007 | 02:19 AM
OH,,, what about goin from a "Drive by Wire" TB to a Cable TB.....
how is that accomplished??
I have my stock 2000 PCM if that will make it easier....
Old Jul 7, 2007 | 05:51 AM
Quik's Avatar
5 year bitches!
just remove the wires and add a cable TB. go in the computer and wipe out the settings for the ETC
