2001 tahoe 5.3 to 6.0
I also wanted to know about putting in a 08 6.2l vortec with active management.
I am very mechanically inclined and lots of connections with gm.
I would wonder if blackbear could tune my ecu for that. And if there would be any extra wiring would required. I know it's fly by wire, I know 03-07 you can change it over to my original cable throttle. But is that possible to do on 07+?
for an 01 to a 08+ is a different reluctor wheel on the crank.. i believe they make a box for that but its goin to be a lil work
here is the box
http://www.lingenfelter.com/mm5/merc...gory_Code=C163
here is the box
Nice so that would be almost a simple plug and play harness for the crank. Do you think the rest would basically bolt up since its just over bored 6.0? I just don't want to have to change computer would be a pain to get my dad to fix.
Hey fellas (and ladies if their in here too!)
I'm a newb at this whole custom truck/car game. I have a 2002 chevy tahoe LT with a 5.3 motor in it. 171k on the original motor and body and the motor recently started to give me some trouble. My mechanic advised me to think about rebuilding or buying a new motor as opposed to trying to fix everything that was starting to break down on the old one. SOOOOO my question to anyone who can possibly help me is if i consider swapping the motor, can i 1. upgrade to a 6.0 and 2. if i can, what and where should i be looking to purchase a motor. Pretty sure they don't have a motor grocery store near my house in NJ lol.
Any advice, ideas, thoughts, wisedom would be extremely appreciated! Thanks in advance.
DJ | Graphic Designer | Photographer | Cinematographer | Special FX | Lover of all things that go Vroom
I found one in NJ through AA Auto Salvage with 30k miles for 2k. It's from a 2009 2500 silverado salvage. I'm actually going with a new crate engine I found, so i won't be buying this one. Maybe they still have the motor?
I need some advice. This is my first engin swap all on my own. I feel list already lol. Putting tye 6.0 from a 06 yukon denali into a 2002 chevy tahoe LT. What should I be aware of. Will I need tye transition from the 06 yukon denali as well or anything else? Any solid advice would be appreciated.
You will use the 2002 wiring harness & computer. If the Tahoe uses a throttle cable you will use the Tahoe's throttle body. If the Tahoe has a return fuel line (two fuel lines) you will need the Tahoe's return fuel rails as the 06 is a returnless system. It's probably easier to just swap the intake over to the newer engine. Use your Tahoe's flexplate and transmission. Should be an easy engine swap.
SLOPONY
20
Oct 18, 2016 06:05 AM
rojeho
Aug 8, 2015 07:20 PM
