160 t-stat
Old Jul 22, 2007 | 02:45 PM
BlownHD's Avatar
Default 160 t-stat
I see a lot of people running a 160* t-stat, Is it a good mod on a full bolt on truck, make any power etc?
Old Jul 22, 2007 | 04:40 PM
truckmann's Avatar
I don't think it is worth it unless you have e-fans and can re-tune for the lower temp. Even then I don't think the gain is much more than piece of mind. Just my opinion.
Old Jul 22, 2007 | 09:14 PM
my black ss's Avatar
yeah not a real power builder but does increase fuel millage a lil bit and prolong life of your motor
Old Jul 22, 2007 | 09:43 PM
gmforlife's Avatar
use the search, but here's a link i started a little bit ago, should answer your question.
https://www.performancetrucks.net/fo...d.php?t=395035
Old Jul 23, 2007 | 12:33 AM
way2much_01's Avatar
how much do they run $ wise? I was told that my truck dont have a t-stat I have 05 avalanche 5.3 is that true?
Old Jul 23, 2007 | 07:25 AM
They all have thermostats(from the factory that is). The 05 and up have a separate thermostat. The 99-04 have the stat built into the waterneck housing and it is replaced as a unit. Its located where your lower radiator hose connects to the water pump. Hope this helps.
Old Jul 23, 2007 | 08:45 AM
gmforlife's Avatar
I just got a thermo, no housing, it fit right in. '03 and up you just need to buy the thermo, older years you need to get the thermo and the housing, hopefully that pertains to an avalanch, but i would imagine it does. I would first buy a stat and see if it goes in, if it doesn't you should go back and order the correct housing for whatever stat you end up with.
Old Jul 23, 2007 | 01:34 PM
Sorry. I guess it is 03 and up.
Old Jul 23, 2007 | 02:58 PM
thanks...when you change the stat do you have to drain the coolant?
Old Jul 23, 2007 | 03:12 PM
TarheelZ's Avatar
Nope...you'll lose a little bit when you disconnect the hose from the t'stat housing, but that's it.
