160 stat install?
Old Feb 4, 2009 | 04:48 PM
BIRCHZ71's Avatar
Default 160 stat install?
anybody have a good link on instructions for swapping out the themostat? i think i know what im doing but wanted to verify before i start.
thanks,
steve
Old Feb 4, 2009 | 04:54 PM
LoweredZ71's Avatar
Get everything out of the way of it and a 10mm socket and and a decent size pair of chanel locks to take the hose off it. Very simple once you get to it but i changed mine when i put the efans on it so theres alot more room.
Old Feb 4, 2009 | 05:09 PM
BIRCHZ71's Avatar
is it neccesary to retune after the new stat is in....i hear of people running a little rich
Old Feb 5, 2009 | 12:05 AM
budhayes3's Avatar
PT's Slowest Truck
I don't know exactly what needs to be changed in the tune, but I'm sure that adjustments should be made to optimize power and efficiency after the 160* t-stat install. Hopefully somebody who knows exactly will chime in, as I'm very curious as to what adjustments are necessary.
Old Feb 5, 2009 | 12:18 AM
viciousknid's Avatar
Where's the Beef?
I've yet to even see any reason to do a 160 swap on these. The only adjustments I seen by doing some quick browsing is the Idle Learn minimum temp is like 174. But operating temperature is still going to be between 190-200 from everything I've read
Old Feb 5, 2009 | 12:28 AM
budhayes3's Avatar
PT's Slowest Truck
My operating temp is around 175ish due to my efan settings being 180 on and 173 off.
Old Feb 5, 2009 | 12:31 AM
Where's the Beef?
I wonder if it makes much difference for the Idle Learn to be lowered then?
Not to say there aren't more things to change. There are several sectors that read the ECT but most are max temeratures or well below operating.
Old Feb 5, 2009 | 09:07 AM
BIRCHZ71's Avatar
just figured it wouldn't hurt...24 bucks for a slightly cooler running motor sounded like a good deal to me.
Old Feb 5, 2009 | 11:07 PM
TX Tahoe Z71's Avatar
I have read from many people on here that you will drop about 1 mpg with it. I was considering the same thing. Don't know if this is with people who did not tune for the t-stat though. Someone please correct me if I am mistaken though.
Old Feb 6, 2009 | 11:05 AM
budhayes3's Avatar
PT's Slowest Truck
I didn't drop any MPG with mine, but I also let my tuner know that I was installing it (PCMforLess). Not sure what adjustments were made in regards to the stat.
