160 degree T-stat a good idea in cold climates?
Old Jun 24, 2005 | 11:29 PM
budhayes3's Avatar
PT's Slowest Truck
When do these trucks go into closed loop...I thought it was like 137*f or something like that?
I always used 160* stats in my older vehicles with no problems in New Jersey winters...I'm curious to see how often my efans operate with my 160 stat this winter
Old Jun 25, 2005 | 12:10 AM
Texas Terminator's Avatar
11 Second Club
depends on the air temperature. at 0C (32F) for example, it will go into closed loop at around 60C which is 140F. at 10C and up, it will go into closed loop around 50C or 122F.
Old Jun 25, 2005 | 01:36 AM
thunder550's Avatar
High on diesel fumes
Originally Posted by Texas Terminator
cooler operating temperatures will certainly increase mileage not to mention increase engine life. the only reason 195's are used today is for emissions, old school motors came with 160's for the longest time until the EPA caught up.
I thought warmer temps meant better gas mileage. You said yourself 195 is used for emissions, which should be lower when you're getting better mileage??
Old Jun 25, 2005 | 09:12 AM
sd155racer's Avatar
Originally Posted by OBXMarine
I've also heard that the 160* stat increases mileage due to the "open Loop" condition. I think my TT300 and 6.0 is the source of my city mpg woes. I get 18 on the Highway.
To directly answer the question, I have no complaints about my 160* stat in cold weather (Pennsylvania winters). I would actually recommend it since the truck's cabin warms up so much faster.
Are you serious? WTF did you put in your cheerios this morning? I live in NY and run a 160 therm, and ran it last winter for the first time -
Here's what I found -
1 - Your gas mileage goes to **** during the winter.
2 - The cab takes longer to heat up, and does not get as warm. Sometimes during races, and on the way to races, I found -28 degree weather, and had cold feet the whole time....
3 - In the summer it kicks *** - better gas mileage and performance gains. I just got 425 miles on 1 tank of gas on a road trip.
Old Jun 25, 2005 | 09:13 AM
sd155racer's Avatar
Oh yeah - and during the winter - no performance gains - mine WILL be coming out in the fall.
Old Jun 25, 2005 | 09:31 AM
01Blackerado's Avatar
It looks lilke your problem is really the hypertech program that you use Mine did the same thing until Nelson Performance tuned it out!! Like I said, we have long and hard winters here as well!!! This whole eastcoast does especially down here in Balt/Wash. NO vehicle is going to take to the amount of things that you have, named in your signature, properly unless they are tuned in for it. Look at my sig you have about the same amount of stuff and like I said I HAD similar problems!!
Old Jun 25, 2005 | 09:51 AM
sd155racer's Avatar
Check my new thread -
Old Jun 25, 2005 | 10:52 AM
11 Second Club
warmer temps equal detonation. the higher temps just cause the fuel to keep burning not only throughout the combustion cycle (ok, maybe a little better mileage but not much) and through the exhaust.
like i said earlier, go to the happy medium and get a 180. it will drop your temps a bit and still give you the best of both worlds.
Old Jun 25, 2005 | 11:50 AM
budhayes3's Avatar
PT's Slowest Truck
FWIW, I've been noticing that everyone's gas mileage seems to be going to **** in the winter for about the last 5 years ever since the C.A.R.B. has the colder climates using winter blend fuel...our customers come to the shop complaining about it all of the time.
I've always had great heat with 160* stats in the past, and it comes up super quick since the coolant is flowing through the heater core sooner. It may be a different story this winter with this truck since the stat seems to have a bit of a different design to it to make it a 160* than the one's I've used in my small block Chevy's of the past. I noticed when I was installing it that it was "spring loaded"...seems to rest on the housing keeping it partially opened...kinda like the BB mod. (my stat's an SLP...not sure if the other 160's out there are the same)
BTW, where in NY are ya? upstate?
Old Jun 25, 2005 | 11:56 AM
Bish's Avatar
I loose 1-2 mpg every winter due to reformulated fuel usage here in winter. If I go back to my mileage log, I can tell you the date they changed it at my primary station (or at least the date I first got RFG in my tank). Goes right back up in the spring.
