160 or 180 T-stat with Radix
Old Jan 31, 2005 | 10:09 PM
Last Call's Avatar
TOTM: January 2007
Default 160 or 180 T-stat with Radix
Like the title says, what would be better. I'm going to get e-fans, and was just wondering what would be better. Will this set up be fine in the summer when towing a boat?
Old Jan 31, 2005 | 10:22 PM
BlownChevy's Avatar
blownerator
25 Year Member
I would go no colder than a 180! The e-fans will be a good mod for you! Call me tomorrow and I can get you the bracket you need.
Old Jan 31, 2005 | 10:35 PM
James B.'s Avatar
The lower the coolant temperature is allowed to stay the more wear the internals will endure. The amount of wear vs. coolant temp is actually inversely exponential to a point. Optimal for wear, emissions, and economy is 195 degrees. Optimal for maximum boost while still preventing the computer from setting codes or staying in open loop is 160 degrees. Running a 180 is a good compromise between 160 and 195. If you can run the 180 without getting knock retard, run that one. If it's pinging then you pretty much have to run the 160.
Old Feb 1, 2005 | 02:48 PM
Last Call's Avatar
TOTM: January 2007
Can you PM me your phone number please?
Old Feb 1, 2005 | 02:51 PM
BlownChevy's Avatar
blownerator
25 Year Member
www.magnacharger.com
Ask for Brian. I am out for about 1.5 hours.
91LT16SpeedFormula
Oct 17, 2015 08:01 PM
redbird555
Sep 30, 2015 09:28 AM
bagged7104SS
Sep 24, 2015 08:42 PM
99bluefirebird
Sep 17, 2015 08:05 PM
