160* thermo? does it really help?
Old Jul 25, 2007 | 01:29 PM
92GMCsierra's Avatar
Default 160* thermo? does it really help?
160* thermostat does it really help? i just put in a 195*, should i switch it? i have a 350 small block, 5.7
Old Jul 25, 2007 | 08:41 PM
lawson4450's Avatar
i have a 160 in my 99 with a 4.8 and it runs great
Old Jul 25, 2007 | 09:16 PM
Silver-Dollar's Avatar
if you do not like a/c at idle, get a 160.
Old Jul 25, 2007 | 09:43 PM
what is the advantage of it?
Old Jul 26, 2007 | 06:31 AM
I guess I should add that between the pulleys and 160 thermostat, a/c is non existant at idle. The advantage is that the valve opens at 160 degrees allowing the coolant to start flowing through the motor sooner. After warm up, I see a max of 185-190 degrees on 90+ degree days when sitting still.
Old Jul 26, 2007 | 06:51 AM
zippy's Avatar
How in the hell is that related?
Old Jul 26, 2007 | 07:41 AM
see post above. I restated that between the pulleys and thermostat, a/c is non-existant. Its probably just the pulleys causing the lack of a/c.
Old Jul 26, 2007 | 07:59 AM
truckmann's Avatar
A lower temp stat will allow the engine to run a little cooler and thus generally allow a little more timing and a little less heat soak. Most likely you will not notice any gain. I had a high flow Stewart water pump and a 160* stat one my old 383 for a short while. I switched to a 180 because it just took to damn long to warm up and that engine was a cold blooded beast.
Old Jul 26, 2007 | 09:24 AM
lawson4450's Avatar
i havent had a problem with warm ups on my truck the ac is cold and the heat is hot lol i mean it works great for me maybe i just got lucky i dont know
Old Jul 26, 2007 | 09:47 AM
i'm running 195*, should i atleast run a 180*?
thanks for the impute guys
