125% duty cycle on injectors
Jun 23, 2005 | 10:13 AM
Quote: Are you using the stock pump, can it supply enough pressure?
Are the injectors from a 8.1L a simple swap out?
What do I need to change in the way of tuning?
thanks for the help guys
Simple swap yes. But then you have to get the injcetor flow rates and a few other things changed/tuned or it wont run right or at all.
Reply 0
Jun 23, 2005 | 11:18 AM
Will the 5.3 stock fuel pump be able to supply enough pressure for 8.1L injectors?
Reply 0
