111 lsa and driveability?
Old Nov 28, 2006 | 04:49 PM
Sport Side's Avatar
Originally Posted by treyZ28
I'm pretty sure -8 is more negative than zero :smash:
Thanks. I always here though, "Is negative less?"
XLR8NSS's Avatar
Adkoonerstrator
Originally Posted by Ruffrider5.3
EFI live will not tune your ride. It is for logging purposes only.
Yes, he will be able to tune his truck with EFILive Flashscan which is what he is getting.
Old Nov 28, 2006 | 04:51 PM
treyZ28's Avatar
might want to edit it to say more negative = more overlap
Old Nov 28, 2006 | 05:05 PM
Sport Side's Avatar
No, the higher the negative value would be less overlap. Are you just reading what I wrote wrong? Maybe it wasn't stated clearly. Tell me what makes it more clear to you and I can edit it.
People get confused when you put a negative value for overlap. "How can you have negative overlap?" In other words, there is none @ this part of the lobe.
Like I said, I know you are aware of all of this, so just tell me what makes it more clear and I can restate it.
Old Nov 28, 2006 | 05:12 PM
treyZ28's Avatar
Sorry, I was misreading it.
You said
The more negative you go, the less overlap you have. So, the 220/220 - 110 cam has 8* more overlap than the 220/220 - 114.
but did the math on the 114 LSA cam first. Brain Fart/Assumption.
I thought you were saying the 114 has more overlap.
It is kinda misleading because neither has overlap. the 114 cam has an 8 degree space between lobes and the 110 has the intake lobe start right when the exhuast lobe ends.
Old Nov 28, 2006 | 05:13 PM
Sport Side's Avatar
I figured that was what it was. I should of used a 230/230 - 112 vs. a 230/230 - 110 where both have overlap.
Old Nov 28, 2006 | 05:33 PM
02sierraz71_5.3's Avatar
Im gonna go ahead and throw in my recommendation even though its futile.
but what the hell Im at work and bored
You can have a low lsa with less duration and make more power and have better drivability, especially with xfi type lobes and the stock heads and intake.
216/222 110/108 .58 lift xfi lobe
Old Nov 28, 2006 | 05:37 PM
Sport Side's Avatar
You can have a low lsa with less duration and make more power and have better drivability, especially with xe type lobes and the stock heads and intake.
216 -.58X'' and a 222* - .58X''... Do you have part numbers or any more specs on these lobes? Where did you find them?
Old Nov 28, 2006 | 05:40 PM
they came out of my head, custom grind baby
Old Nov 28, 2006 | 05:41 PM
RandomHero's Avatar
I had no driveability problems with the 222/224 112 it just needed a 3400 stall to really come out the hole good. I wouldnt be shy about running that cam just be prepared to run a decent size stall with it, a 3K isnt going to get it done in your ec truck, unless you have just have a freak truck.
I was under the impression that more overlap meant you would make less peak horse power but your powerband would be bigger. Am I mistaken?
