1 serious question!!!!!!!!!!!!!
Old Aug 22, 2007 | 10:30 PM
1blueSS's Avatar
formerly 1fstrst (11/25/2010)
Default 1 serious question!!!!!!!!!!!!!
I have an 05 5.3 with a mild cam. I want to put a little bigger cam. headers with a 3000 stall or a little bigger, and a 90mm fast intake on in the future. I would like to put a set of pacesetters lt's on it with NO cats into a X pipe now( true duals). Is that the best setup to run??? If so should I go 3" all the way or should I put some sort of reducer somewhere in the system. I'm not even sure if a set of high flow cats would be better. I do know if I go with no cats I need to upgrade my HP tune cause I do live in an immission county. Please any assistance would be appreciated. Thanks!!!
Old Aug 22, 2007 | 10:34 PM
TouchOfEvil04's Avatar
Myself i woudn't do the true duels. I'd do a normal pacesetter off road y-pipe and just run a cutout for those times you want the extra flow.
Old Aug 22, 2007 | 10:37 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
I run long tubes with 3" collectors thru hi-flow cats, an X pipe and then reduced to 2.5" thru a set of 12" oval Borlas to back behind the tires.
Old Aug 22, 2007 | 10:41 PM
1blueSS's Avatar
Why the high flow cats?? I've talked to you before in the past I know you know your chit. I would like to know why before I go with the extra expense.
Old Aug 22, 2007 | 10:45 PM
Grumpy5.3's Avatar
He lives in Cali, its hard for him to slip an inspector 20 bux and get a sticker. Not that it happens or anything, but I wouldnt run but a 2 1/2 in pipes. You need torque to get that big biotch moving, and smaller pipe gives you better torque, 3 in is overkill unless you had like a 434, mp122, or some crazy stuff like that.
99Silverado5.3's Avatar
Probably because of the **** Californian emmision laws
Old Aug 22, 2007 | 10:54 PM
1blueSS's Avatar
The pacesetter lt's exit with 3" I agree with you with the 2 1/2 " Where SHOULD I REDUCE IT???...LOL I know I can beat the PCM emmission test with the HP tune. I do not need to pay anyone off ...lol
Old Aug 22, 2007 | 11:15 PM
1blueSS's Avatar
Why Borlas??? is that a personal preferance? I kinda wanted something different like a set of bullets.
Old Aug 22, 2007 | 11:41 PM
Grumpy5.3's Avatar
Oh but you do, in NC you have to pass a visual inspection also. I know I do them!!!!!
Old Aug 22, 2007 | 11:44 PM
rivierakid55's Avatar
im running lt/s with hi flow cats then cutouts, then x-pipe then two bullets. couldnt be happier with the sound now that i ran the pipes back a little further.
