1 bolt or 3 bolt cam in 2008 aluminum 5.3L engine?
I have an aluminum 5.3 out of a 2008 Avalanche. It has DoD/AFM and does NOT have VVT. That's all I know about it.
What kind of cam and cam gear does it have? 1-bolt or 3-bolt cam gear?
are you planning to do a cam swap?
call the dealer with your vin and ask about the cam gear, they'll have a picture
personally I switched to a 3 bolt cam/gear when I did mine
the easiest thing would be call the dealer, cause I haven't seen any info on whether or not there's an RPO code, or an engine casting that will tell you. mine is an LMG, that had 1 bolt DOD and vvt! which was random. so its luck of the draw
Thanks for the replies guys. Sounds like I'll have to open it up in a few weeks when it's in front of me. Every time I call the dealer for something like this they want the VIN, and I don't have it.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
