1.8 Rocker Arms or 1.85 - Worth The Money?
Old Nov 24, 2002 | 01:28 PM
silent1's Avatar
Default Re: 1.8 Rocker Arms or 1.85 - Worth The Money?
i have the 1.8 crane rockers. they give mostly top end power, but to get their full potential you're gonna have to go with a bigger bore. i'm not sure which engine you have, mine is the 5.3. if you're just going to go as far as bolt on's then i'd say save your money because they're pretty damn expensive for the little power you'll get out of them. but if you're going ***** out, it'll make for a great valvetrain set up. that's my opinion.
Old Nov 24, 2002 | 02:11 PM
parish8's Avatar
single digit dreamer
spend the money on a cam, that way you can get any lift you want and adjust the duration too. seems like a complete cam set up isn't any more money, arent those things like $600?
Old Nov 24, 2002 | 02:39 PM
Brandon Boomhauer's Avatar
yeah im going to go with a cam/springs before anything like rockers....
Old Nov 24, 2002 | 02:56 PM
DuckOfDeath's Avatar
1.6? Aren't the stock ones 1.7? Just curious...
Travis
Old Nov 24, 2002 | 03:15 PM
they know nothing about the new ls1 based motors...
they have nver been schooled on 'em <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
they still think its based of a 350 block...
which arent most rockers for them like 1.5 = whic would be why he would say 1.6 right... you want to go 1.6 to 1.7 or 1.7 to 1.8 right? always to a bigger number...??
Old Nov 24, 2002 | 05:00 PM
You would want to go to a higher ratio to open the valves more. So, if a stock 350 chevy had 1.5's, then 1.6's would be an improvement. I found that the stock LS1's are 1.7. So, the 1.8 would be an improvement, but 1.85 would be a bigger improvement. But, like Silent1 said, the cam and rest of the valvetrain would have the biggest effect - the rocker arm ratio would enhance whatever valvetrain changes are made.
Old Nov 25, 2002 | 12:25 AM
Default 1.8 Rocker Arms or 1.85 - Worth The Money?
Some of my old school buddies are tellin me to swap out rockers when i swap my cam. they dont know much on the ls1 based engines... hint - one said to put some 1.6 rockers on.......
anyways would they be a worth while investment, and make some extra power?
vipergtrdj
Sep 16, 2015 07:06 PM
chvy=power
Sep 8, 2015 11:06 AM
2004gibbstruck
Sep 7, 2015 06:05 PM
xerox17
Sep 5, 2015 01:23 PM
