08 vortec max oil pressure
As cold as it gets there you may be better sticking with lighter oil. Down here where it's still 80 degrees most of us generally run heavier oils hence better oil pressure. I run 15/40 synthetic diesel oil in all of my vehicles including my 6.2 vmax truck.
I noticed my VMax stopped going into V-4 AFM like it should. I didn't think too much of it because I just replaced air filter with AEM dryflow and AirRaid MIT. I thought the truck needed to "learn" the new airflow from the mods. I even began to to think these new mods were adding more load and keeping AFM from enabling. I was about to put the stock crap back in, but then I noticed oil pressure seemd low. It was hanging around 15-20psi at idle and would go to 25 if a reved engine.
My oil life was only at 80% but I changed it anyway with 10w-30 and replaced oil filter with ACDelco and voila! Oil pressure slightly north of 40 and AFM working like a charm and picked up 2mpg. I honestyly think it was the filter. It had plenty of oil and only half quart low.
Same problem in my new truck here. These high volume OE pumps are known to have the pressure relief valve hang open on a poorly deburred pump housing. I lost all oil pressure on one before... My fix will be removing dod, the lifters, and swapping the high volume unit out for a standard volume melling pump.
