05 E-fans Installation Questions
Old Dec 27, 2004 | 08:26 AM
VortechC5's Avatar
Default 05 E-fans Installation Questions
I just bought some 05 truck electric fans that I want to install on my 03 Silverado. I want to get all of my parts lined up for this project and have some questions.
  • I need a 34" radiator. What is the GM part number for the correct radiator? Is there a better place to get one than from GM?
  • I did a search and found references to Nelson fan harnesses. Where to I get one? I did not see Nelson on the sponsor list.
  • Will all of my radiator hoses, tranny cooler lines, etc. bolt up to the larger radiator?
  • Is there anything else that I need other than programming for the fans?
Thanks.
Old Dec 27, 2004 | 09:08 AM
zippy's Avatar
i thought a truck like yours should already have the larger radiator?
Old Dec 27, 2004 | 09:46 AM
NothinButBowTies's Avatar
I thought that the larger radiator was for the 6.0, not the 5.3
Old Dec 27, 2004 | 09:55 AM
VortechC5's Avatar
That's what I thought too that only the HD and SS trucks have the larger radiator. I'll measure mine to be sure though.
Old Dec 27, 2004 | 02:17 PM
SnakeOiler's Avatar
The HD and 6.0 trucks should have the large radiator. I believe everyone gets the smaller one.
Old Dec 27, 2004 | 02:56 PM
KySilverado's Avatar
Thanks.
34" radiator comes n 6.0L powered vehicles. I'm about to put some in my 03 also.
1> I've also looked for the GM part number online. GMParts direct says go to the dealer. Closest I've found is here. Radiator Barn
2>Harness here Nelson Performance Supose to be anyway
3> Should be a direct bolt in. Think we have an oil cooler in the radiator to.
4> Tuner to turn on the fans outputs from the PCM and to set the setpoints!
Good luck and post how it goes
Old Dec 27, 2004 | 05:00 PM
VortechC5's Avatar
Thanks for the help everyone.
I checked mine out and it does have the small radiator without an oil cooler. It looks like there is plenty of slack in the lines/hoses to reach to the new radiator.
I'll give Nelson Performance a call and order the harness. Then all I'll need is for FlashScan to be released so that I can turn the fans on...
Old Dec 27, 2004 | 07:50 PM
CHarris's Avatar
How much is the harness?
Thanks,
Cory
Old Dec 28, 2004 | 08:27 AM
VortechC5's Avatar
I read on another forum that the harness is $80.
Thanks,
Cory
Old Dec 28, 2004 | 12:32 PM
Arigom's Avatar
Is the 05' fans better than the LS1 fans? Looks like it cost about $100 more to go with the 05' fans.
