04 6.0l vs. 99 6.0l differences
Old Feb 26, 2005 | 09:10 PM
Default 04 6.0l vs. 99 6.0l differences
What are the internal differences between these 2 years. I have an 04 LQ4 6.0l right now but 3 pistons have skirt damage but the bore is fine.. Can I use pistons/rods out of a 99 LQ4 6.0l??
Thanks...
Old Feb 27, 2005 | 10:17 AM
IMD's Avatar
IMD
Banned
bottom end is the same. 01 up got aluminum heads.
Old Feb 27, 2005 | 11:10 AM
Yelo's Avatar
Rotating assemblies are the same (other than the crank end-pad thickness on the '99-'00)......but there is at least one block difference, the '01-up 6.0 blocks have a better main oil gallery design that was inherited from the 5.7
Old Feb 27, 2005 | 11:20 AM
hyper's Avatar
i wouldnt put a 99 engine in my truck, or even buy a 99.
Old Feb 27, 2005 | 11:37 AM
L-EATER's Avatar
11 Second Truck Club
Somewhere around '03 they got coated skirts on the pistons. My '01 did not have this but the crate motor I purchased in '04 did. I don't see any reason why you couldn't use the non coated pistons in the newer motor.
Old Feb 27, 2005 | 11:43 AM
14 Second Truck Club
The block would probably just need to be honed for the coated pistons.
Old Feb 27, 2005 | 11:49 AM
ktmrider's Avatar
Should be no problem to use the pistons/rods for LQ4 to LQ4.
Make sure NOT to use the crank, the flexplate bolt flange is slightly thicker on the 99 model and would cause TC/tranny mounting woes.
calsdad
Jun 14, 2023 11:07 PM
twake_410
Apr 14, 2016 09:58 PM
Staggered 02
Oct 9, 2015 05:19 PM
gmcyukon
Oct 5, 2015 06:20 AM
sTNT971
Sep 26, 2015 06:27 AM
