03 speed limiter
Old Nov 12, 2003 | 11:44 PM
Flyer's Avatar
Default 03 speed limiter
This is annoying the **** out of me! It seems like it pulls really hard up until 95, then it slacks off and eases up to 100 where it stops pulling completely.
Every mod I have done yielded almost no increase mph on a strip I use to test. It seems everytime I run it I get to 95 and it starts falling down.
Has anyone else experienced this? Is it a new 'feature' where it hits the speed limiter soft instead of hitting it and cutting out? I hope EDIT will let me take this 'soft' limiter off or at least raise it up a bit. Does anyone have any info on this?
Old Nov 13, 2003 | 12:03 AM
2003Silvyrado's Avatar
Yeah, thats the speed limiter, any good programmer should let you remove it or move it up to match what tires you're running.
Old Nov 13, 2003 | 12:12 AM
Flyer's Avatar
Do you get the same soft approach like thing I'm talking about at 95? Any idea on what it's doing to achieve this? I tried to log it the other day when I was running EFILive, but I couldn't get a stretch of road to run up to 100 safely.
Old Nov 13, 2003 | 01:21 AM
It did, my limiter is at 110 now to match my shitty goodyears, it still cuts out the same though. (edit- starts cutting out just before 110 mph IIRC) I don't know how it cuts it out. I wonder though if it doesn't just ease back on the throttle, since its an electronic throttle.
Old Nov 13, 2003 | 02:03 AM
Flyer's Avatar
Yours still cits back at 95? That is gonna be so frusterating!
That's a good thought .. lemmie check some logs.
Old Nov 13, 2003 | 02:17 AM
Flyer's Avatar
That's it .. throttle is pulled back to about 58% and gradually backs off as it approaches 100.
It still shows to be in PE mode judging by the STFT's and the 02 readings.
On a side note .. I'm getting -10 degrees timing when it shifts. Wonder how much that kills performance?
Old Nov 13, 2003 | 12:14 PM
BigTex's Avatar
That -10 is torque management, plain and simple.
The new electronic throttle is the speed limiter. No more cutting off fuel, it just automatically eases off the throttle, keeping you at a nice solid 95, but no more.
I moved mine up to 145 with LS1 edit, but I haven't tested it out.
bearden86
26
Nov 15, 2015 03:58 PM
turbo6c3
Oct 5, 2015 06:11 PM
BlownHD
Oct 3, 2015 12:24 PM
Lthompson
Oct 2, 2015 12:45 AM
Rockrz
Sep 29, 2015 09:07 AM
