02 Sensors and LT's
Old Oct 10, 2007 | 03:50 PM
03sierraslt's Avatar
Default 02 Sensors and LT's
I have heard of many people having issues with 02's sensors and LT headers due to the lack of heat I guess. So my question is has anyone found a 02 sensor that responds well with LT's? I am thinking of going back to CLSD and need some new 02's.
Old Oct 10, 2007 | 07:00 PM
I had to replace mine with Bosch O2's. Works so far. I think it is due to increase in heat. They burn up.
Old Oct 10, 2007 | 07:07 PM
dewmanshu's Avatar
Moderately Differentiated
I don't think it's due to burning up. I have an EGT gauge that says different. I went with the vette rears, due to the higher wattage heater in them. No matter what you choose sometimes it works for others and not for some. So many variables. I shortened the switching of the o2's (switching is the problem anyway) and it seems to work fine. Hell I even get a little leaner PT driving with the o2's swithcing shortened.
Old Oct 10, 2007 | 07:12 PM
You got what sensors dewey? The vette rears, for use in your bank 1&2 upstream sensors correct? How much did you have to shorted the switching?
Damn Replacements are expensive, where are you guys getting yours from?
Old Oct 10, 2007 | 07:25 PM
dewmanshu's Avatar
i bought the vette 13111 sensors. My switching is
350.01358 350.01358 350.01358 350.01358 350.01358 350.01358 451.01235 539.98504 580.00406
in the 02 Rich/Lean vs Airflow tables
and 24.00000 31.00000 43.00000 51.00000 51.00000 51.00000 43.00000 43.00000 43.00000
in the closed loop porportional base vs airflow mode
I have a cam as well, so there is need for my adjustments as well. You may n ot need such refining of the rich/lean interpretations.
Old Oct 10, 2007 | 07:26 PM
I just got raped in the butt for mine. Just under $200 from O'Reillys
Old Oct 10, 2007 | 07:29 PM
I have no idea what you just said.
The vette o2's have a different connector, I guess you just cut and put the other connector on?
Old Oct 10, 2007 | 08:04 PM
dewmanshu's Avatar
That's what I did, yes. Just match the numbers on the ends.
The confusing part above is if you have access to tuning software.
Old Oct 10, 2007 | 08:25 PM
My 02 rich/lean vs. airflow is 451 across the board.
