02 Sensor
Hey guys I am working on a harness off and on and I made a mistake when I was deleting the rear 02 and accidentally cut off the Front driver side 02 sensor. I went back and sauntered the 02 back on, but now that I am looking at it I am not sure if I accidentally added one of the rear 02.
. I Cant remember I have been working on this thing off and on. Can some check to see if these type of plug-ins match your front 02 sensors.
The engine harness is from a 5.3L 2001 I know for sure that the 6.0L harness the 02 plug-ins came reversed. So if someone can chime that would be great.
I took a picture the way that it sits is that the left is the driver side right is passenger. The driver side is what i FFFDDD up.
Thanks
. I Cant remember I have been working on this thing off and on. Can some check to see if these type of plug-ins match your front 02 sensors. The engine harness is from a 5.3L 2001 I know for sure that the 6.0L harness the 02 plug-ins came reversed. So if someone can chime that would be great.
Thanks
I'm going to be crawling under my truck a little later to take some suspension pics for another member, if you don't have an answer already by then, I'll take a look and take some pics if you'd like
I found the front sensor to be the flat 4 pin, and the rear to be the square 4 pin, just like Truckshop said.
I took pics, just didn't get online last night so I didn't upload them. I could do it some time this weekend hopefully if I get a second...got a crazy weekend set up with something to do Fri, Sat, and Sun, so it may be tough, but I'll try.
Wrecker 426
Sep 30, 2015 09:39 PM
