02 5.3 m90 build
Old Sep 3, 2014 | 05:02 PM
Fritzjd2's Avatar
Registered User
Default 02 5.3 m90 build
Purchasing my M90 eaton tonight and looking for a little advice, the truck is an 02 sierra 5.3, 212/218 522/529 112lsa cam, hardened pushrods, pac 1218 springs, LS1 efans, Longtube headers ory with a cutout at the end of the Y. Currently have it tuned by justin at blackbear. I am pretty good with fabbing and dont think I will have an issue making the sidemount. I was going to go ahead and pin the crank while I'm at it.
My major questions are what upgrades to the fuel system will be needed if needed at all? I assume it will at least need bigger injectors and possibly a pump but don't have a clue what size.
I also am not famliar with forced induction systems. I think I am going to run an air/air intercooler, but aside from the supercharger and intercooler what else will I need ie blow off valve, bypass valve..
My last question is will my truck throttle body bolt up to the m90 from a grand prix and if not does anyone know where an adapter plate can be found?
Thanks in advance
Old Sep 3, 2014 | 05:14 PM
FFDP's Avatar
It likely won't bolt up, unless your throttle body has the same pattern and fits on. Then you need to figure out some sort of gasket.
The M90 has a BBV right on the side.
And just so you know the stock 3.8in pulley would only make 6-7 psi on a 3800 from the factory, so add 2 more cylinder and boost will go down. You will likely want to step down to a 3.0/3.2 or even like a 2.8 to spin that thing fast enough to make some boost.
I own a pontiac myself but never heard of anyone doing one with a 5.3.
Old Sep 6, 2014 | 08:22 AM
Pro52R's Avatar
Its a tiny supercharger. It's going to be way inefficient imo.
Old Sep 6, 2014 | 09:23 AM
N20zuki's Avatar
I have to agree, I have a M112 and that's even too small to make decent power. On a bone stock 5.3 with nice flowing exhaust I am making 8lbs on a 3.0 pulley and cranking out 430whp and that is in a car with a T56.
If you were to fab anything I would of bought a MP112 or a M122 from a GT500 or Cobra and built from there as it will atleast support the air you will need to make power.
I remember somewhere a guy did a build going from a M90 to a M122 and then some other bigger blower and the M90 made 2-4lbs of boost pullied down and lots of heat.
Vash3233
Sep 22, 2019 01:18 PM
USMCvet0311
Aug 14, 2015 10:28 PM
JordanH
Aug 8, 2015 07:59 PM
05GMC4.8
Aug 7, 2015 09:55 PM
06 4.8
Jul 15, 2015 07:17 PM
