01 zo6 cam for pulling
Old Mar 8, 2004 | 12:26 PM
RED2K's Avatar
Default 01 zo6 cam for pulling
After I get my tune from Nelson and getting some times from the track my truck is going back to a tow rig. I was thinking about changing the gears to 3.73 and the cam to a 01 ls6 cam. How would this cam work for pulling about 8000 lbs? We had opening at this track this weekend so I have the fever.
Old Mar 8, 2004 | 12:28 PM
F8L Z71's Avatar
Bad idea.
You dont gain squat till after 4500rpms.
I'd go with a custom ground cam that increases TQ more than HP. With the Z06 cams you get a bunch more HP waaay up high but you barely gain any TQ.
Old Mar 8, 2004 | 01:36 PM
RED2K's Avatar
I might go with a stock cam and give the person my 216 for doing the install
Old Mar 8, 2004 | 02:18 PM
Banned
get a custom grind like a 215/215 .555 112, someone dynoed with that cam and made quite a bit more low end torque and a ton better high end.
Old Mar 8, 2004 | 02:25 PM
BigTex's Avatar
Actually, smoke_ur_50 installed the 215/215 cam and said it might be a little too much.
You can use the 01 LS6 cam with an adjustable timing chain. Advance it 4* to prop up the low end. It will idle like a baby. My 01 LS6 cams gains were all in the upper range, and it started pulling harder from 2500+. Anything below that wasn't great.
Old Mar 8, 2004 | 03:12 PM
1BADHD's Avatar
Get a 212/212 with high lift and pull away!!
Old Mar 8, 2004 | 07:08 PM
big tex on the money ,had same set up in my truck worked very good .tow 8000lbs
Old Mar 8, 2004 | 07:11 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
I happen to have a 01 Z06 cam and springs for sale cheap in the classifieds! Holla!
Old Mar 8, 2004 | 07:47 PM
BigTex's Avatar
thanks!
Old Mar 8, 2004 | 08:02 PM
mudz5.3's Avatar
Isn't that lift a little high? And wouldn't the lsa, higher be better for low end? Something like 116 or so
