01 engine into 05 truck
Old Jun 28, 2008 | 02:19 AM
05chevyguy's Avatar
Default 01 engine into 05 truck
can i put a 2001 lq4 into my 2005 rcsb v6 truck?
Old Jun 29, 2008 | 12:57 PM
xlcooplx's Avatar
no. thats absurd.
Old Jun 29, 2008 | 01:06 PM
00ChevyScott's Avatar
Wearin' da big hat
lol..
Old Jul 2, 2008 | 11:26 AM
05chevyguy's Avatar
haha wow i didnt mean like that. i meant what would i have to do since i have to have a same year or newer computer...
Old Jul 2, 2008 | 11:43 AM
Wearin' da big hat
I just put an 06 engine into a 00 truck, so it is definately possible.
You would need to put your intake manifold on it because of the fuel system and throttle body. I also had to change my oil sending unit, not sure if that would be applicable in your situation
Old Jul 2, 2008 | 12:22 PM
coldkillinTA's Avatar
He has a V6 so my guess would be to get ahold of an 04+ manifold with fuel rails and stuff with the returnless style system (assuming your v6 has the same fuel system as the v8 trucks.) and also a newer comp. and harness
Old Jul 2, 2008 | 12:30 PM
built408's Avatar
computer, harness, complete engine from intake to pan, fuel rails and injectors, someway to connect your fuel lines to the rails, motor mounts, headers or manifolds, all of the accessories like p/s pump, water pump, ac compressor, alt, idler, and tensioner. Some way to connect your a/c compressor to the v6 lines, P/s hoses to connect to the steering gear. And probably a bunch of other stuff I'm not thinkin about.
Old Jul 2, 2008 | 03:21 PM
Wearin' da big hat
well ive got a spare truck intake and DBW throttle body off my 06 engine, and a power steering pump + the bracket for it and the alternator.
Old Jul 2, 2008 | 03:36 PM
GMCtrk's Avatar
Did you read through the v6 to v8 conversion thread?
Old Jul 2, 2008 | 04:44 PM
chevyguy7802's Avatar
+1 on that
