00 5.3 oil pressure probs, need help asap
I tried several different searches and was not able to find a clear answer to my problem. I have a 00 Z71 with a 5.3, I ran it into some water and bent 1 rod and broke 2. I pulled the engine and replaced those rods and bearings, did not touch anything else. Put the motor back and now I have no oil pressure after 2-3 times of starting and running for 10 seconds or so. I pulled the valve cover and no oil to the top of the motor, however the filter was full of oil and I did not add any to it before putting it on. Am I being too paranoid, should it take a little longer to build pressure or did I possibly pinch the O ring when I put the pickup tube back on. I lubed the O ring and tube up well before putting it back on but it did pull down with the bolt instead of seating all the way when I pushed it in. Any info is appreciated.
Pinched the o ring, I wasn't wanting to drop the front diff but I not the bullet and got it done. Just got to figure out the trick to putting it back in without pinching.
Noah Burns
Sep 7, 2015 05:50 PM
superchomper2003
Aug 26, 2015 09:39 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Ferocity02
Jul 17, 2015 07:05 PM
