Yep, another tranny problem thread
Old Mar 10, 2007 | 11:40 PM
  #31
James B.'s Avatar
Originally Posted by 1SlowHoe
Possibly a cut vacuum line thats not bad enough to effect the other gears?
If the line was cut or off, the modulator would be commanding more line pressure. The more the vacuum the less the line pressure.
Old Mar 11, 2007 | 10:17 AM
  #32
KySilverado's Avatar
Well I'm fairly confident that at least its not going to strand me so I can cruise around and try and diagnose. Putting together a scanner config to log tranny data see if it tells me anything.
Didn't know you could log tranny input rpm and output rpm, compare this with engine rpm and I'll be able to tell at least where the slip and how much is happening.
Old Mar 11, 2007 | 09:23 PM
  #33
I've retuned. PWM Maximum 100% across the board, PWM Minimum 90% accross the board and lock the converter part throttle 3rd and 4th at 80mph. Can't make it slip now and 4th looks better than all the other gears. I am concerned about the TC more than trans now. Don't understand it but gonna drive it and see what happens.
On another note my VIG is now a 2900 stall. Thinking about getting it re-stalled back down.
Old Mar 17, 2007 | 08:49 AM
  #34
trever1t's Avatar
2nd fastest 5.3 ECSB
Update?
Trans still holding up........I hope?
walledition
Feb 24, 2026 03:27 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
Pimpinpete
Sep 8, 2015 07:39 PM
Boyes50
Sep 8, 2015 12:06 PM
mayko
Sep 7, 2015 12:24 PM
