yall think a drop will help my 1/4 mile times??
shackle hanger drops change the geometry of the rear end. springs up front change how it will transfer weight. the shock angles change...they usually just dont transfer weight as well. especially the ecsb and ccsb's.
blue cajun took his drop off to gain traction. from what ive seen it works. i did a flip kit on the rear instead of hangers/shackles and so far ive seen results. now i just gotta figure out what to do with my rear shocks and front springs.
A dropped truck that has suspension that works compared to a stock ride height truck with a suspension that works, both in identical conditions...the dropped truck would more than likely out run the stock ride height truck do to aerodynamics. Just my .02.
The keys are what's actually on the rear end of the bars, that contact the adjuster bolts... Can't really have one and not the other. Setting a truck up for optimal performance at the track requires you to look at every corner of the suspension... There's lots going on that needs to be taken into consideration. Spring rates, shocks, placement, preload etc...
And yes, you do have springs on your truck, they're just in the form of torsion bars, not coil springs. They do the same thing.
i did mc shackle and hanger, clamped overload. then mc 2inch spindles. with eibach lowering keys to make it sit just right ( my truck sat level factory, so it sat bulldog bad when i did the normal 2/4 kit). also it went into factory specs on allignment but right on the edge for camber. so im gonna order that 1 degree camber bolt and be good to go. heres some phone pics
