Will 99 gears fit in a 91 rear end?
Old Jun 3, 2006 | 08:59 PM
Dock Rocker's Avatar
Question Will 99 gears fit in a 91 rear end?
I have a shot at a set of 4:10 gears with an eaton unit with all of the bearings and gaskets new in the box for $400.00. I want to buy them but I dont know if the gears from a 99 are interchangeable with an OBS. Guy bought them to tow with and sold the truck before the install.
Dock
Old Jun 3, 2006 | 09:18 PM
Quik's Avatar
5 year bitches!
rear ends dont know years. if its a 8.5/8.6 then yes it can go there. same as in a car
Old Jun 4, 2006 | 07:40 AM
Grumpy5.3's Avatar
The gears will fit if they are 8.5/8.6... The locker will probably not work b/c I think the splines are a diffrent size between the 2...
Brian
Old Jun 4, 2006 | 08:17 AM
TurboGibbs's Avatar
Gears are the same, both should be 30 spline(I think they went from 28-30 spline around 1988), but the carrier bearings are different. I put a gov loc out of a 99 model in my 95 truck and had to find bearings. Go to a "good" parts store and look through the bearing dimension book. They make a bearing that has the same I/D as the 99 carrier and same O/D has the 91 housing but you won't find them doing a standard look up. You must find them by dimensions. O'Reilly had them in stock, don't have the # though
Old Jun 4, 2006 | 09:09 AM
Thanks! I will do my research ahead of time and see if I cant find the bearings early.
Thanks
GB
TAPyvehc93
Jul 23, 2017 10:54 PM
Silveradorst07
Dec 31, 2015 12:04 AM
So.cal Wrk Sled
Jul 26, 2015 12:10 AM
Ketis
Jul 23, 2015 12:37 PM
Sdailey
Jul 13, 2015 09:17 PM
