The "Why" on converter clearance
Old Jan 31, 2015 | 09:15 PM
GREENSIERRA's Avatar
Originally Posted by MrHorsepowerLSx
You could use an 1/8th drill bit to measure for proper clearance...... That's the method that I use and prefer to use. Install the converter the. Stick the bit between the flexplate and converter bolt boss and begin measuring hope that helps
this is the way I check , drill bit works very well
Old Feb 10, 2021 | 07:36 AM
IIGW's Avatar
5 Year Member
Last post was 2015... You guys coming back?
Old Feb 11, 2021 | 10:14 AM
Circle-D's Avatar
Former Vendor
We're still around and happy to help with any questions.
Old May 23, 2021 | 03:35 AM
IIGW's Avatar
5 Year Member
thanks, sending the ask chris form now
Old Jan 26, 2022 | 03:02 PM
reubone's Avatar
What about converter snout to crank hub engagement? Is this not as important as pump engagement? Only reason I ask is because I had a converter that could have spaced so far away from the flex plate that there was daylight between the two.
Old May 25, 2022 | 11:11 PM
Rockrz's Avatar
May have lost the engine
Did you look real good under the hood???
Sorry, that was hard to resist
Old May 26, 2022 | 06:10 AM
reubone's Avatar
I have the same issue. If I fully seat the converter all the way back, there is a ton of space. I also know that if I bolt it up yo the flex plate that it is too far out of the pump. It will drive under its own power and lockup works and everything. I want to go back and shim it so I would like to know if the snout/hub engagement is important too.
Old May 26, 2022 | 07:16 AM
MaroonMonsterLS1's Avatar
yes it is important
it sounds to me like you need a new flexplate to properly space things
possibly yours is coned and has improper spacing.
Old May 26, 2022 | 08:27 AM
reubone's Avatar
Originally Posted by MaroonMonsterLS1
yes it is important
different year models have different flex plates? What should I look for?
Old May 31, 2022 | 11:34 AM
reubone's Avatar
Or should I get a crank spacer
X_Racing1
Oct 12, 2016 08:54 PM
skoal bandit
Oct 13, 2011 08:08 AM
Pjstucn
Aug 16, 2006 04:30 AM
