Who is putting 500-600whp+ through a "Craigslist" 80e w/ Shift kit?
Old Apr 4, 2016 | 06:24 PM
lxcoupe's Avatar
Default Who is putting 500-600whp+ through a "Craigslist" 80e w/ Shift kit?
Is it still kicking?
2wd or 4wd?
If not, how long did it last?
Once it did bite the dust, who's trans did you go with and are you happy?
When your junkyard/ craigslist 80e bit the dust, did you send the converter back to get cut open and cleaned?
Any other info you'd like to share?
Old Apr 4, 2016 | 06:38 PM
Beatdown Z's Avatar
Laid Back
$600 Craiglist 60k mile 2wd 80E, Transgo HD2, Yank PT3600. Been in my truck for about 5 years, but only a couple thousand miles on it, Lol. Motor is a 5.3, a Triple 12 cam, and 76mm on 15lbs.
The last truck I built is a lifted Suburban 2500 with a cammed 6.0 and TVS 1900 blower. I pulled the 200k mile 80E out of it and did the internal dual feed, sonnax valve, and changed a bad bushing. So far that trans is holding up great!
Old Apr 4, 2016 | 07:29 PM
tgui's Avatar
Lxcoupe, your trans OK? I've made it 200 miles on mine if that helps.
Old Apr 4, 2016 | 08:33 PM
lxcoupe's Avatar
Trans is mint, but to be honest I'm surprised (knocking on wood as we speak). I only dynoed 475 to the wheels at 9psi, but that was with ignition issues. I've since fixed those and have turned the controller up to 12psi and logs look good and the truck feels like absurdly quick for 4800lbs. Heading back to the dyno on Wednesday and hope to turn it up to 15psi, if my BAP can keep up. I've done about 20 4wd launches just to get a feel for things and the truck shifts really really good! I was merely curious if other guys had gotten their trucks running and had initial good luck with their stock 80's and then had trouble
And kudos to those 200 miles tgui! If there is anyone who deserves a good trans it is you.
Sending you a pm now!
Old Apr 4, 2016 | 09:28 PM
quicksilverado's Avatar
I put about 80k on a junkyard 80e With a shift kit and 3k tq conv. Had it rebuilt to stock specs and it is still running fine.
Old Apr 12, 2016 | 04:13 PM
Fast355's Avatar
I tuned one behind a Duramax that had around 50K miles and now has over 100K (150K total) behind a Duramax making close to 800 TQ.
Old Apr 12, 2016 | 08:15 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
I'm running a stock rebuilt 2007 model HD-2 shift kit sonnax boost valve i also did the pump mods I'm making around 7xx RWHP no issues
Time2Kill
Dec 29, 2020 11:36 AM
Tig
31
May 9, 2016 12:53 PM
bigtodd
Apr 15, 2016 05:14 AM
lxcoupe
Apr 5, 2016 10:05 PM
urmaster85
Mar 31, 2016 07:36 PM
