Who has lowered an 06 Silverado
Old Jan 21, 2006 | 11:54 AM
onebad96T/A's Avatar
Default Who has lowered an 06 Silverado
Im looking to lower my 06 Crew Cab truck, i have been told i have to buy new leaf springs because the hangers are welded onto the truck.
Anyone have any experence in lowering a 06 Crew Cab.
And i know the fronts dont need spindals just springs
Any help from you guys would help!!
Thanks Lance
Old Jan 21, 2006 | 02:13 PM
NeverSatisfied02's Avatar
I also have an 06 crewcab and im looking to lower it very soon so im glad you asked this question!
I think im going to go with a 2/4 because with a 4/6, i will have to have rubber band tires to tuck with the 22's and i will have no notch the frame. Not only that, it will be so low that i will drag on every speed bump and i wont be able to haul much without bottoming out. 2/4 seems like the better way to go for me since it is a daily driver and id still like to use it occasionally as a truck. I just dont know which parts or components i will need to use to get the drop im looking for. I want to run spindles in the front for sure because if i bag it later, it will save me some money in the long run.
Anyone with info on this topic will benefit both of us!
Old Jan 21, 2006 | 05:21 PM
I think im going with 3/4 drop on my 06 and planing on going to a 20" wheel on all 4 corners, hopefully i will have not have any problems. And yes i agree 4/6 is too low for my use of my truck even tho i dont haul anything but a few kids. I did have a 90 GMC stepside with a 4/6 kit and 17" wheels and pulled my T/A to the track hand full of times and pulled fine but did rub some on the front air dam but no complaints with the 4/6 kit.
I just need info on the rear of the truck i havent even looked under the truck yet so do i need Leafs or hangers?
Old Jan 21, 2006 | 05:57 PM
slammedS10's Avatar
I would just do 3in leafs with a 2in adjustable shackle. Thats what i have( sitting in my room, leafs not on yet truck is away for the winter.)
Old Jan 24, 2006 | 01:40 PM
silverado22's Avatar
i have a 05 and i put a hanger shackle kit in. The hanger kit is difficult to put in but saves ur towing abilities. It is a 2/4 drop on 22's!! here are pics!
http://pg.photos.yahoo.com/ph/seth_b...bum?.dir=/f2a1
Old Jan 24, 2006 | 03:49 PM
I have been doing alot of research on lowering kits for a 06 Crew Cab and to tell you not much out there. The 06 Crew Cab has weld-on hangers to the frame and shackles in the rear so there is no simple kit for the rear for these trucks. So i finally found a solution to get a 3/4 drop i talked to a Tech Rep from Stylin Concepts and he told me i need to use a 4" flip kit from Bell Tech and the front i can do either 3" springs or spindals, springs are 150 bucks and rear flip kit 299.00 no one has really said using leafs just do a flip kit...
What do you guys think?
Vash3233
Sep 22, 2019 01:18 PM
signguy62
Sep 20, 2015 02:05 PM
iregret
Sep 10, 2015 09:00 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
signguy62
Jul 27, 2015 03:42 PM
