Who does 5 lug conversions for our trucks?
Old Feb 12, 2014 | 01:41 AM
oakley6575's Avatar
You don't need a lathe to machine the bolt pattern. It's done on a mill with a rotary table. Or if you lay out the pattern, it can be done on a drill press.
The front hubs is what they stopped doing.
I realize you don't drill holes with a lathe I meant I don't have anything anymore to shave them strait after welding the holes closed. The whole process is something that I can't do with the equipment I have.
Old Feb 12, 2014 | 01:50 PM
dirt track racer 81's Avatar
I did all mine on a drill press.. Welded the holes up and used a grinder to grind them down. Cut the center of a wheel out and tac welded that to the hub as a template and drilled the holes.. Easier said than done as always lol
Old Feb 12, 2014 | 02:08 PM
GMCtrk's Avatar
Would you be willing to do a coupe s sets for the right price?
Old Feb 12, 2014 | 02:14 PM
1FastBrick's Avatar
Custm2500's Rude Friend
I can make you a drill template to use a 1/8 bit. I just need the o.d. of the center hub.
Using a 5 on 4-3/4 bolt pattern???
Old Feb 12, 2014 | 04:40 PM
Let me think about it, it's not really the money it's just the time, I don't have much of it between all the other projects that I'm wrapped up in..
Old Feb 13, 2014 | 12:46 PM
blown02408's Avatar
02 w/ lowest mileage 2800
I did my own conversion using a 1/2 thick cnc'ed wheel spacer modified to accept steel guide bushings so I could swap drill sizes to drill the hubs and the rotors. To fill the one stud hole that falls within the new bolt pattern I cut down a wheel stud, smothered it in epoxy and pressed it in. Once dry I ground it smooth, worked perfectly.
Old Feb 13, 2014 | 11:31 PM
Blown06's Avatar
8 Second Truck Club
Sounds like a good job.
BTW, hows your truck running?
Old Feb 15, 2014 | 07:33 PM
blown02408's Avatar
Thanks! I'll have share some photos and info on the conversion once I get a chance.
Well it was running, but I can't leave anything alone. I have a bunch of projects going on right now so the truck has kind of been neglected. It currently sits like this-
Old Feb 15, 2014 | 07:49 PM
oakley6575's Avatar
Damn that looks good. Any pics of the rear wheel/tire set up?
Old Feb 16, 2014 | 03:17 PM
blown02408's Avatar
Not yet, the rear is more apart than the front end. I'm welding in taller c-notches, redoing the shock crossmember, adding a driveshaft loop, mini-tubbing the bed, moving the leaf springs under the frame, and ordering a narrowed S60 rear as soon as I get my tax return.
