Where to get air bags for 05' yukon, rear only.
I need air bags in the rear because when I pull much weight the back end squats too much. A had the back loaded with 500+lbs and about 500lbs tounge weight and it just squated way too much. I want to be able to add air to keep it level with a trailer. Any ideas? I want to hold out on air shocks because I kinda like the smooth ride I have now.
I wish I could just add some helper bags like the regular truck guys but they dont fit coil springs.
I was in the same boat as you on my Tahoe. I bought the Air Ride Tech bags and that was a mistake. If you want a very bouncy ride then that kit is for you. I now have a Mcgaughys 2/3 with there helper bags. The helper bags go inside the coil's. I have yet to give mine a try. I just put any heavy **** in my truck now. Air Lift is the company you are looking for, if this is what you want. I had the part number but can't find it. Call Summit Racing and they'll hook you up. The install is easy it is pretty much straight forward. Hope this helps..
I dont want a bounch ride, I was hopeing for a stock ride except when I have 500lbs+ tongue weight.
Thanks for the help, I'll look into it and maybe see about just fabing up some brackets for extra shocks and put some air shocks in. Why cant it be as easy as the truck helper bags............
As for fabbin something up. I also tried this route but there was not enough room under there.
There was always something in the way no matter how I tried to design it. But goodluck. Truck helper are soo much easier I agree.
Corvette454l88
Sep 1, 2016 01:24 AM
5.3Caprice
Nov 7, 2015 08:56 PM
shupe
Aug 5, 2015 06:45 PM
