what's the widest tire I can fit out back?
Old Jan 11, 2009 | 11:40 AM
95 bright teal's Avatar
Rubbing is caused more by you tire height also, so dont forget about that, a 285/50/18 would probably not rub at all up front.
Do you really want a taller tire out back, if your staying stock height maybe but your losing gear and putting more weight farther from the wheel.
stoechiometric also put a 305 on a titan rim, but he had to widen his fenders so they didnt stick out past the fender, ill see if i can find his pics
Old Jan 11, 2009 | 01:00 PM
Cuerva's Avatar
11 Second Truck Club
Just to give you an idea on what I'm cooking. Here's a crappy phone pic of mine.
Don't know how wide or the backspacing of the 18's but the NNBS 20's are 8.5" wide I believe; Thes are a friends wheels/tires; Toyos 315/35/20 and tuck fine on mine with rolled lips, his fronts are 275/40's and those didn't fit on mine (too low). I haven't bought them cause they didn't have the 255/40/20 I wanted for the front. Have to wait for the new Toyos, if not I plan on going with 275/35/20 Nittos 555 (Front) and 305/35/20 Nitto 555R Drag Radials (Rear).
Old Jan 11, 2009 | 05:07 PM
GMCtrk's Avatar
Originally Posted by texas1964
The escalade wheels were a good buy, but now that your wants/needs are changing, you will probably be happier in the end making it all work together.
I try to be a "measure twice, cut once" kinda guy, and here is as far as I have got. Currently my 2008 Silverado has stock 20's wheels and stock 275/55/20 tires
I am looking at the Centerline ultra archer or stingray III 20x8.5's and hoping to find Toyo Proxes ST's - keeping 275/55/20 size in front and then 305/50/20 in the rear. Because the centerlines are lighter than my wheels, I will actually reduce total tire/wheel weight and get more grip out back, which is one of the few ways to get both more performance, and save a bit of gas.
You could go with this idea as is, but you will probably change it to make it yours, which is cool, so keep us informed.
I never anticipated ~400rwhp!
The real question is guys....will stepping up to a 305/60/18 make a significant increase in grip over 285/60/18?
The 305s will work with the escalades, I don't care if they stick out a little. Actually I think it'd like that fat look better. Looking at my truck now from the rear the 285s actually look skinny...they seemed nice coming up from stock 255s, but I want a fatter look and better grip now. All these guys on here post videos of cammed 6.0s just blowing off the rears...Id like to avoid that.
Old Jan 11, 2009 | 05:15 PM
skyhighsami's Avatar
no title here
I have 305/40/22s on my wife's Yukon XL and they tuck just fyi
Old Jan 11, 2009 | 05:22 PM
It all depends on the offset, im not sure what they are on the cadillac wheels, but at stock height tucking isnt an issue
Old Jan 11, 2009 | 06:47 PM
texas1964's Avatar
[QUOTE=GMCtrk;4098217]I never anticipated ~400rwhp!
QUOTE]
I have not done the tire change yet, but a 285/60/18 is 11.2" wide and a 305/60/18 is 12" wide, so that is a 7% increase is surface contact. I assume that will help, but I dont know by how much. Hopefully we can get some feedback from those who have already done the swap.
I assume the reason trucks with bigger power spin like crazy is that trucks have poor front to rear weight ratios, and when guys do weight saving tricks to trucks, like taking off the spare tire and replacing the rear bumper with a roll pan, they mostly take weight off the rear, which is a mixed blessing for launching.
Old Jan 12, 2009 | 01:05 AM
TXsilverado's Avatar
im past 400 rwhp and the nitto 555r 305/45-18 is by far the best tire ive used so far. it may be a little short for a stock height or lifted application but it worked out great for me.
its on an 18x8 wheel and wore perfectly even at 27psi. i run 19psi most of the time though since its not a DD anymore.
Old Jul 2, 2024 | 09:57 PM
54inches's Avatar
I know I am necroing this thread and it pisses people off, but FDK.
Anyways, I really wanted to stay around stock height, maybe a tad higher since I will be going from 3.23s to 3.73s.
I run square honeycombs but staggered tires.
255/50/20s up front. About to be lowered 1"
295/50/20s out back. Already lowered 2".
As of this post, no one makes a tire in a similar height, any wider. Yes, they do make them much wider, but they are several inches taller, which I don't want.
315/45/20 would be ideal.......
Just an FYI for anyone lo0king for the WIDEST tire AVAILABLE for the back of a 2wd Cat-eye slightly lowered.
Old Jul 3, 2024 | 07:50 AM
shakenfake's Avatar
Shlumpt
5 Year Member
Why not just run 295/50r20 up front? How close are you to rubbing/how much rubbing does it do?
Old Aug 11, 2024 | 06:36 AM
Drspencer's Avatar
5 Year Member
I'm running a 305/50/22 and dropped on spindles and shackles on a '13 Silverado crew cab with High Country wheels. It rubs a little bit lock to lock and had to use a 1/2" spacer in the back with Excursion studs. Ran the same on my Avalanche in a 305/55/20 (IIRC) and had the same issue, rubbed a little bit turning with 08-13 LTZ wheels.
The rear, you'll have to run a different offset to keep it from hitting the frame if you don't want to use a simple spacer.
thunder550
Oct 8, 2015 04:53 PM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
FlowmasterMufflers
Jul 22, 2015 12:47 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
FlowmasterMufflers
Jul 9, 2015 11:35 AM
