Whats the best? Detroit locker, tru trac or Eaton
Old 07-08-2010, 11:02 AM
nonnieselman's Avatar
I cant complain about my Eaton LSD.. its been put thru some work and made it this far.
You cant go wrong with either tho..
The detroit locker is a serious one, not too fun on the street from what ive seen.. Its more like a spool.
Old 07-08-2010, 06:45 PM
05RST2NV's Avatar
Originally Posted by 1Bear
It will actually take more effort to unlock the clutches, not more to lock them. The main downside of the 800# springs, besides costing somewhere around 100 bucks more added to the total of the LSD, is the chances of inner tire wheel spin is greater when going through corners or in loose dirt or gravel. I too like the Eaton LSD, but all of them have their place where they excel with some overlap in capabilities and you just need to decide what you’re really going to be using your vehicle for the most.
Its going to be a street truck, running on the street mostly but making frequent trips to the track and hopefully laying down some 10 sec time slips.
Old 07-08-2010, 07:22 PM
02 w/ lowest mileage 2800
blown02408's Avatar
I have a detroit locker and love it! You just can't give it too much power around tight turns or it won't unlock.
Old 07-08-2010, 09:38 PM
05RST2NV's Avatar
^^^What's that truck run in the 1/4??^^^ Looking at the sig its a beast!
Old 07-09-2010, 12:27 AM
11 Second Hall Moniter
AKlowriderZ71's Avatar
These things are one solid chunk of steel
Ya, sure they are........
Old 07-09-2010, 12:34 AM
Wearin' da big hat
00ChevyScott's Avatar
I are has a truetrac
Old 07-09-2010, 12:35 AM
Baltimore Whore
Mangled03gmc's Avatar
Yah no clutches/springs buddy.. All steel parts That is what I meant by that...
Old 07-09-2010, 01:09 AM
And that is why it's not rebuildable. When it gets worn & noisy, it has to be replaced.
But the truth is, both are good units. Both are designed well. Both are proven to be strong.
Old 07-09-2010, 01:19 AM
Baltimore Whore
I agree with ya there^^^^
Butttt
When it gets worn and noisy I will buy a new unit, I am sure that will be many years.. I bet the rebuild kit for the LSD is a pretty penny..
Old 07-09-2010, 01:37 AM
Bout $100 or so, and the clutch material in the diff fluid doesn't damage the diff bearings, so they can often be reused. When the truetrac wears out & gets noisy, the metal in the fluid pits the bearings & races.
Quick Reply: Whats the best? Detroit locker, tru trac or Eaton
