what year 4l80e can i get to fit the LQ9
Old Feb 7, 2010 | 10:34 PM
SatisTraction's Avatar
Default what year 4l80e can i get to fit the LQ9
I have a 2004 escalade LQ9 that i am swapping into a 85 c10. I have to get a tranny so it may as well be the 4l80e. what year models can i use? any years that i should avoid?
Old Feb 7, 2010 | 10:43 PM
nickleahy23's Avatar
i believe anything from 99-07 will work just fine, maybe even the older ones...
the only difference in the 99-00 was the 6.0 had a spacer on the flexplate because of something with the crank being longer...but im not sure how that works going the other way..at least a 01-07 will be easiest..
Old Feb 8, 2010 | 06:05 PM
how about one froma 2003 8.1 big block truck?
Old Feb 8, 2010 | 07:30 PM
VortecHOjunkie's Avatar
03 truck with a 8.1 would be an allison I think. If it was out of a cargo van it might be an 80. I have no idea what the differences are though.
Old Feb 8, 2010 | 08:14 PM
im pretty sure thats an allison behind it like said before...the only 4l80's that were behind a 8.1 woulda been in a burban or yukon xl 2500
Old Feb 8, 2010 | 08:40 PM
hmm. well it is a 4l80 and it behind the 8.1 502.
Old Nov 26, 2013 | 08:57 PM
ShredSled's Avatar
So does the 80e from a 2500 8.1 equipped SUV have the same bell housing as those that came from behind a 6.0??
Old Nov 26, 2013 | 09:29 PM
good question..idk if they changed bellhousings for the 8.1 and duramax? since the dmax vans come with a 4l80e..
Old Nov 27, 2013 | 05:52 AM
Suburbazine's Avatar
I think they all share the same LS bolt pattern, give or take an extra bolt hole. If I recall correctly the 60E, 80E, ZF650 and Allison all share the same bellhousing configuration.
PS: the ZF650 gets my vote for a C10 swap. You'll never kill it!
Old Nov 27, 2013 | 06:19 AM
00buckshot's Avatar
They all share the same bell housing, at least all that I have seen. Hell even the Allison we just replaced here at work would bolt up to an ls
