What thickness metal for shock mount brackets?
Old Sep 2, 2010 | 08:29 PM
brent5631's Avatar
Are you going to weld to the factory round crosstube?
skeet's Avatar
Originally Posted by BlackGMC
pictures would be great! Are you sure you used 1/16? That is some pretty thin stuff.
about 99% sure BUT then again its been a good while lol!! i'll get some pics tomorrow .. hold on not to sure now lol gonna go snap a pic ..
there will be 2 brackets per shock, boxed on one side, so a 3 sided box.
yep thats how i did mine
Old Sep 2, 2010 | 08:35 PM
BlackGMC's Avatar
Resident Retard
yep welding to the factory tube and to the existing shock mounts...
Old Sep 2, 2010 | 08:37 PM
brent5631's Avatar
Ok. I think even 1/8" will be fine if you make the brackets tall enough and tie them together to reduce any buckling.
Old Sep 2, 2010 | 08:39 PM
Quik's Avatar
5 year bitches!
well i know i can weld 3/16 easily, pushing it to 1/4 is a safety concern for me, i don't want them failing plus it not recommended with the literature that came with my welder...
a good 240v mig welder will do 1/4 without thinking. Mine clearly says that and is capable of 1/2 with a few changes
it also comes down to technique. Unless you have a lessor model then yea but a good 240v welder will do 1/4 without a problem if the person using it can run a steady bead
Old Sep 2, 2010 | 08:49 PM
BlackGMC's Avatar
Resident Retard
Well i am happy for you and your welder. Like stated previously i don't feel comfortable welding that thick of material. I just looked on the inside panel of my lincoln, it does say it will do up to 5/16 but i would have to use .045 flux wire...
Old Sep 2, 2010 | 08:51 PM
skeet's Avatar
here ya go :
Old Sep 2, 2010 | 08:53 PM
BlackGMC's Avatar
Resident Retard
Thanks for the pics! pretty sweet setup you have going there!
Quik's Avatar
5 year bitches!
is it a lincoln 180 model that you have? nice smartass reply, you asked for insite. metal is my trade so i replied back... welding 1/4 is no different technique then 1/8
Old Sep 2, 2010 | 08:58 PM
skeet's Avatar
thanks corey, it'll give ya an idea how you would have to also notch them so they'll sit right in the bracket !!
