What gear lube do I need to use ?
Old May 18, 2008 | 11:01 AM
Mangled03gmc's Avatar
Baltimore Whore
Question What gear lube do I need to use ?
This might sound dumb, but what fluid do I need to run, is there a particular weight I should use. Also should I run a poss additive in it, since it is a trutrac, doesn't have the clutches in it like a reg eaton?? Will SAE 75W-90 do the trick??
Thanks John
Old May 18, 2008 | 12:44 PM
Baltimore Whore
Welp I got lucas 75-90 so hope that works..
John
Old May 18, 2008 | 03:46 PM
budhayes3's Avatar
PT's Slowest Truck
75w-90 is the right stuff...and you don't need an additive with a trutrac since it is a locker and not a limited slip
Old May 18, 2008 | 09:29 PM
joehawkz71's Avatar
the additive is in there for the clutch type tunes....helps the clutches grab and not slip! i think its called friction modifier.......
Old May 18, 2008 | 09:44 PM
Baltimore Whore
Thats what I figured, drove the truck about 50 miles this eve with the new gears, unit. It works just fine...
John
Old May 20, 2008 | 11:48 PM
fastrt's Avatar
11 Second Truck Club
I talked to eaton about my posi and my friends true trac and eaton told me to use 80/90 mineral oil based and not synthetic, but synthetic should not hurt IMHO.
Idryfly5
Sep 2, 2022 08:55 PM
Oobray
Jun 13, 2022 03:38 AM
blownss27
Aug 14, 2020 08:27 AM
jtphelps289
Sep 29, 2015 12:00 PM
Cowboy Tom
Sep 5, 2015 04:29 PM
