What to do? no traction
Old Mar 22, 2008 | 11:18 PM
TouchOfEvil04's Avatar
Originally Posted by terravast4
Cal-tracs and get some bF goodrich G-force kdw nt's. Some spin but a hell of a lot better.
What does the "nt" stand for?
I know kdw is killer dry wet...
Old Mar 22, 2008 | 11:36 PM
bluecajun5.3's Avatar
11 Second Truck Club
bring it back to stock height.
that's what i'm gonna try out this wed.
Old Mar 23, 2008 | 12:30 AM
Derek @ EDO's Avatar
FormerVendor
I dont see Cal-Tracs doing anything for you since you have zero wheel hop.
I would leave your suspension alone and focus on getting a tire that will work,
you have had enough trouble getting rid of the vibration.
If you are looking for a dual use tire (street/track)
http://store.summitracing.com/partde...5&autoview=sku
Your current tread width is a little over 8 inches with those et streets
The above Drag radial will give you more surface area for traction.
If for a track only tire get the Hoosier slicks.
Old Mar 23, 2008 | 12:45 AM
What wheels should i get to run the hoosiers? Arn't the stockers a little to small and you can normally get better traction from a little wider rim?
Anybody running aftermarket rims on the hooisers?
Old Mar 23, 2008 | 12:48 AM
I thought cal- tracs helpped lift the front so to speak? for better weight transfer?
I gotta do something you saw what it does when i nailed it at 38....
Old Mar 23, 2008 | 12:53 AM
95 bright teal's Avatar
my guess is once you get some slicks and actually start grabbing the road the hop will come, oh and your 60's are bad but your pulling up top. get some good slicks!
Old Mar 23, 2008 | 12:55 AM
i could get two 16x8's from centerline to match the 4x20's lol. they are on sale afterall haha. 20's stingrays up front 16 stingrays in the back.
Old Mar 23, 2008 | 12:57 AM
FormerVendor
Caltracs IMO does not help with weight transfer.
Stock wheels will work fine with the Hoosiers.
When you start looking into different wheel combos you will find it hard to get a wheel with the appropriate backspacing to keep the tire inside the inner fender.
You can find the wheels but the are $$$.
Bogart makes some!
My truck will be down a few weeks for the build etc.
Feel free to use mine to see if they are right for you.
If AP and myself can pull good 60fts with them i dont see you having a problem.
Old Mar 23, 2008 | 12:59 AM
Bogart makes some!
Tis true. Might have to try em out and see what tha slowass truck will do.
Working on your stuff btw...taking forever.
rcsb is getting detailed as well.
Old Mar 23, 2008 | 01:03 AM
FormerVendor
Wanna go to NPR Wed?
