Vibration after drop shackles
Old Apr 25, 2014 | 07:24 PM
TAPyvehc93's Avatar
Default Vibration after drop shackles
So i installed 2" drop shackles from auto zone on my NNBS RCSB 4x4 and now i have some vibrations. I can really notice it on deceleration between 20-30 mph but i also notice it throughout other speeds. From what i read, i should not have had any problems with vibrations from just 2" drop shackles on a rcsb. I did tighten the shackles with the tires off the ground but i cant really see that being the problem. So my only guess would be that i need some shims? Anyone have any problems like this? I will loosen and tighten the shackle bolts tomorrow to so if that helps, but if it does't go away what size shims do you recommend?
Old Apr 25, 2014 | 08:34 PM
Chevy_King1500's Avatar
every truck can be different, even the same truck with the same parts
best bet is to measure your driveline angles and buy the appropriate shims
Old Apr 25, 2014 | 09:12 PM
Ferocity02's Avatar
Yes, needing shims is common with drop shackles. As mentioned, measure the angles and get the right shims.
Old Apr 25, 2014 | 10:16 PM
TAPyvehc93's Avatar
How do i go about measuring the pinion angles?
Old Apr 26, 2014 | 02:08 PM
TAPyvehc93's Avatar
anyone?
FlyingLow
Nov 24, 2015 10:05 AM
06droppedcrew
Nov 17, 2015 10:56 PM
01silvy
Sep 26, 2015 10:20 PM
dhorner77
Sep 11, 2015 05:10 PM
