Vibrating problem at 70-80 mph
Well since I got the truck it vibrated between 70-80 mph anything higher or lower it's fine. I had it realigned it helped a little I put new shocks in that might of helped a little more I put new wheel hubs that helped the most now it only does it some times usually as I'm traveling down the highway and I take a curve it starts to vibrate ... Any ideas or help would be appreciated ...
I've had tires balanced many times many sets of wheels also of difrent trucks that ran fine with them
What truck? The reason I ask...
http://www.duramaxforum.com/forum/ex...-pit3009j.html
check the u-joint caps were they engage into the yolk there is clips that center them sometimes people loose them or they fall off then the u-joint is off center causes a nice vibration seen it lots,if not pull each drive shaft and check all the u-joints visualy for being loose or spraying rust. If you dont see anything remove the shafts and move the joints check for stiffness and you can even pull the caps look for chatter marks
