vette servo ???????????
Old Oct 27, 2007 | 02:03 PM
  #21
Phantom's Avatar
11 Second Club
you dont have to drop the y-pipe or any of that. just remove the heat shield that shields the tranny from the cat. no need for all that extra work
Old Oct 27, 2007 | 02:07 PM
  #22
CHEVRACER83's Avatar
+1 I DID MINE IN PLACE... ALL I TOOK OFF WAS THE HEAT SHIELD
Old Oct 27, 2007 | 02:10 PM
  #23
Gator's Avatar
Same here..just the heat shield
Old Oct 27, 2007 | 02:46 PM
  #24
GMC_DUDE's Avatar
Ditto. There was even a groove in the body which allowed removal of the servo assembly in one piece.
Edit: Potential gotcha. Before disassembling everything, measure how far out (or in) the servo cover protrudes from the housing. When you reassemble, be sure the cover is seated to the same distance. Sometimes things don't seat properly the first time, and the cover will LOOK like it is on, and the snap ring will FEEL like it is engaged, but such is not the case. Driving the truck with things in this state can cause the cover to pop off in a cockeyed fashion, breaking the housing and ruining the entire transmission case. When I did mine the assembly just would not seat properly, so I gave up on it for the day. Came back to it the next morning and it popped right in! Go figure...
Old Oct 28, 2007 | 06:06 PM
  #25
dustin_z71's Avatar
i have a bone stock 4L60E wantin to put a servo in it but to scared that the crisper shift will hurt the tranny... does it change the rev limit or does the shift from gear to gear improve and become shorter and faster
Old Oct 28, 2007 | 06:28 PM
  #26
eallanboggs's Avatar
Don't be skeered! It doesn't change rev limiter. Engines rev, transmissions don't. Put the pedal all the way to the metal and you'll feel the difference as soon as your transmission shifts from 1st to 2nd. There is a discernable SOP difference. No more mushy shifts where you're wondering if your transmission just shifted or not. Just do it.
Old Oct 28, 2007 | 07:30 PM
  #27
dustin_z71's Avatar
im not skeered thats the problem thats why i undergoing tranny swap now but i really dont wanna go through the hassle of taking this one out to put a new one in.. just wouldn't mind havin a firmer shift in the stock tranny but at the same time dont wanna tear it up again either
Old Nov 4, 2007 | 09:48 PM
  #28
VHO 6.0's Avatar
This will work on a 4l65 right?
Old Nov 6, 2007 | 11:27 AM
  #29
bodyguard6799's Avatar
anybody have the GM P/N ??
Old Nov 6, 2007 | 09:37 PM
  #30
Can someone at least give tell me about what year vette to tell them at the dealership?
