u-bolts
Old Aug 21, 2007 | 07:43 PM
stormgrey's Avatar
Default u-bolts
can any one tewll me the torque specs for the u-bolts for the rear springs by the way my truck is a 2000 silverado 4wd also i need the specs for the 2wd if there is a diffrence. thanks
Old Aug 21, 2007 | 11:16 PM
IMD's Avatar
IMD
Banned
as tight as your 1/2" impact will make them.
Old Aug 22, 2007 | 11:19 PM
negativeswitches's Avatar
:agree: with IMD
mabye more with a breaker bar if you have a crappy impact
Old Aug 23, 2007 | 06:52 AM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
I don't know about a breaker bar, but I usually use a long handle 1/2" ratchet and tighten the snot out of the u-bolts.
Old Aug 23, 2007 | 08:57 AM
WJ MARK's Avatar
Are you removing the blocks from the rear and using 2wd u bolts?
Old Aug 23, 2007 | 10:29 AM
kbracing96's Avatar
------From the GM service manual------
# Install the washers and the nuts to the U-bolts.
Tighten
* Tighten the nuts (w/ attached washer) to 72 N·m (53 lb ft).
* Tighten the nuts (w/o attached washer) to 137 N·m (101 lb ft).
Black02Z71
Oct 7, 2022 08:40 PM
GM1697
Sep 2, 2015 02:22 AM
Ferocity02
Jan 16, 2013 11:54 PM
Steve-O-08
Jun 4, 2011 07:48 AM
Rhino79
Apr 12, 2010 08:12 AM
