turbo 400
Old Mar 21, 2007 | 11:58 PM
  #21
80e is prob where Ill go, 9s no 10s maybe
Old Mar 22, 2007 | 08:48 AM
  #22
vanillagorilla's Avatar
Originally Posted by whitt1
Rossler makes a trans brake for a 4L80E.It's on their web site.The only down side for the 4L80E is the tall 2.48 first gear,but it offers closer gear spacing with a 1.48 second 1.0 third and a .75 fourth.
Did you check the price tag on that? You might want make sure you're sitting down.
A T56 is almost 20 year technology. A PG is an even older design than a TH350/400 but obviously the guys that run those are slow and they don't know what they're doing either.
Old Mar 22, 2007 | 11:08 AM
  #23
Quik's Avatar
5 year bitches!
a PG is horrible unless your all out racing and losing OD is just senseless unless your ride is track only. most rides are street rides and should have OD
and stock PG are junk, its when you build them, stock 350/400 are junk unless you build them, 60/80 are junk unless you build them can y ousee a pattern? all stock trans are junk...its when you build them when they are strong
Old Mar 22, 2007 | 11:23 AM
  #24
I assumed we were only talking built transmissions here. Stock trannys in a performance truck is like oil and water.
There are plenty of cars that have PG's on the street even in the most extreme form. In a heavy truck no, but street/strip cars live with them even with 5000rpm stalls.
You're forgeting two things when determining transmission streetability and gearing, and that's rear end ratio and tire diameter.
Crunch the numbers: TH400, 1:1 3rd gear with a 31.9" tire and 3.08's vs. T56 .5:1 6th gear with a 28" tire and 4.88's. Not too much difference regarding cruise speeds. Turbo's like high gears, so going with a 3.08 with a 1:1 3rd gear makes it work for me. It's equivalent to having an 80E with 4.10's which is what a lot of people run around here with less parastic drag, less weight, ability to shift myself and have a transbrake. Not to mention the TC choices and the availability and cost of replacement parts.
You can get almost any set of gear ratios too for a TH400 from John Kilgore.
Old Mar 22, 2007 | 11:29 AM
  #25
Quik's Avatar
5 year bitches!
for you is one thing for DCracer is another. and if you were comparing to me i run on 30" tall tires on hte street for cruising.
from my experience with 400/80 you need gearing but im also around NA applications for most part
but for you best of luck
Old Mar 22, 2007 | 12:57 PM
  #26
DC? GM lol i think the 80e is gonna be best for my setup, i just wish there was a way to get rid of all the aluminum in them... like my 60e has eater 3 pumps now, it sucks... but Im sure the 80e will hold up just fine
Rafe19
Oct 18, 2016 12:27 AM
J.costello
Aug 26, 2015 06:33 PM
Sierra1320
Aug 15, 2015 08:04 PM
